Why Does the Taylor Series of exp(-x^2) at x = 0 Start with 1 - x^2?
The Taylor Series of f(x) = exp(-x^2) at x = 0 begins with 1 - x^2 due to the evaluation of the function and its derivatives at zero. Although the first derivative f'(0) is zero, the second derivative f''(0) is -2, which contributes to the x^2 term in the expansion. The series can also be derived by substituting t = -x^2 into the Taylor expansion of exp(t), leading to the series for e^-t^2. The absence of an x^4 term in the second derivative is explained by the definition of the Taylor series, where the second derivative contributes only to the x^2 term. Thus, the first two nontrivial terms of the expansion are correctly represented as 1 - x^2.
cytochrome
The Taylor Series of f(x) = exp(-x^2) at x = 0 is 1-x^2...
Why is this?
The formula for Taylor Series is f(x) = f(0) + (x/1!)(f'(0)) + (x^2/2!)(f''(0)) + ...
and f'(x) = -2x(exp(-x^2)) therefore f'(0) = 0?
Can someone please explain why it is 1-x^2?
Mathematics news on Phys.org
Although f'(0) = 0, yet f''(0) will NOT be zero.
The formula is (x^n)/n! (with the sigma crap in front)
0! is 1 and x^0 is 1
Just substitute x=-t^2 and you get the series for e^-t^2
Then why doesn't the second derivative term have an x^4?
Here's what HomogenousCow is trying to say. Consider the expansion of ##\exp(t)## where ##t=-x^2##. The Taylor expansion of ##\exp(t)## is $$\sum_{n=0}^\infty \frac{t^n}{n!},$$ so substituting gives you $$e^{-x^2}=\sum_{n=0}^\infty \frac{(-x^2)^n}{n!}=\sum_{n=0}^\infty \frac{(-1)^n x^{2n}}{n!}.$$
The second derivative term does not have an ##x^4## by its definition: Each term is given by ##\frac{f^{(n)}(0)x^n}{n!}## (for MacLaurin; for Taylor about ##c##, it's ##\frac{f^{(n)}(c)(x-c)^n}{n!}##). When you plug in 2, you get $$\frac{f''(0)x^2}{2!}.$$ In this case, ##f''(0)=-2##. This cancels with the ##2!## in the denominator, so you end up with ##1-x^2## as the first two nontrivial terms of the expansion.
It looks like you are trying to combine two different ways of finding the Taylor series of e^{-x^2}
1) Using the basic definition: the "x^2" term has coefficient f''(0)/2 so that the second derivative term, by definition, involves x^2, not x^4.
2) Replacing x in the Taylor's series for e^x with -x^2. In that case, the term that you get from the second derivative of e^x has x^4 but that has nothing to do with the second derivative of e^{-x^2}. That term comes from replacing x with -x^2 in the f'(0) x term of the Taylor series for e^x.
Thread 'Video on imaginary numbers and some queries'
Hi, I was watching the following video. I found some points confusing. Could you please help me to understand the gaps? Thanks, in advance! Question 1: Around 4:22, the video says the following. So for those mathematicians, negative numbers didn't exist. You could subtract, that is find the difference between two positive quantities, but you couldn't have a negative answer or negative coefficients. Mathematicians were so averse to negative numbers that there was no single quadratic...
Insights auto threads is broken atm, so I'm manually creating these for new Insight articles. In Dirac’s Principles of Quantum Mechanics published in 1930 he introduced a “convenient notation” he referred to as a “delta function” which he treated as a continuum analog to the discrete Kronecker delta. The Kronecker delta is simply the indexed components of the identity operator in matrix algebra Source: https://www.physicsforums.com/insights/what-exactly-is-diracs-delta-function/ by...
Thread 'Unit Circle Double Angle Derivations'
Here I made a terrible mistake of assuming this to be an equilateral triangle and set 2sinx=1 => x=pi/6. Although this did derive the double angle formulas it also led into a terrible mess trying to find all the combinations of sides. I must have been tired and just assumed 6x=180 and 2sinx=1. By that time, I was so mindset that I nearly scolded a person for even saying 90-x. I wonder if this is a case of biased observation that seeks to dis credit me like Jesus of Nazareth since in reality...
