Explaining Taylor's Remainder Formula for Convergence of Taylor Series
In summary, we can use Taylor's remainder formula to show that the Taylor series for f(x) = e^{5x} about x=0 converges to f(x) for all x. By setting z_n = 0, we can obtain an upper bound for the remainder term R_n, which approaches 0 as n goes to infinity. Therefore, we can conclude that the Taylor series for f(x) converges to f(x) for all x.
jegues
1,097
Use Taylor's remainder formula to show that the Taylor series for f(x) is about the point indicated converges to f(x) for all x.
[tex]f(x) = e^{5x}[/tex] about [tex]x=0[/tex]
Since,
[tex]f^{n}(x) = 5^{n}e^{5x}[/tex],
Taylor's remainder formula for [tex]e^{5x}[/tex] and c = 0 gives
[tex]e^{5x} = 1 + 5x + \frac{5^{2}}{2!}x^{2} + \frac{5^{3}}{3!}x^{3} + ... + \frac{5^{n}}{n!}x^{n} + R_{n}[/tex]
Where [tex]R_{n} = \frac{5^{n+1}e^{5z_{n}}}{(n+1)!}x^{n+1}[/tex]
There are two cases we must consider:
Case 1: If x < 0 then,
****NOTE: The following line is the line I am confused about,****
[tex]x < z_{n} < 0,[/tex] and [tex]|R_{n}| < 5^{n+1}\frac{|x|^{n+1}}{(n+1)!}[/tex]
How do they go about making this conclusion? Do they work from the this in the following manner?
[tex]x < z_{n} < 0[/tex]
[tex]5x < 5z_{n} < 0[/tex]
[tex]e^{5x} < e^{5z_{n}} < e^{0}[/tex]
[tex]e^{5x}\frac{|x|^{n+1}}{(n+1)!} < e^{5z_{n}}\frac{|x|^{n+1}}{(n+1)!} < e^{0}\frac{|x|^{n+1}}{(n+1)!}[/tex]
And then take the limit as n goes to infinity on the outside and use squeeze theorem to prove the rest?
Where are they getting the second part of this line:
Also, they are using squeeze theorem around [tex]lim_{n \rightarrow \infty} |R_{n}|[/tex], how come they are only showing one function around [tex]|R_{n}|[/tex]. (i.e. [tex]5^{n+1}\frac{|x|^{n+1}}{(n+1)!}[/tex]) Where is the 0 term?
Once I understand this I will continue and finish off the problem, this is the only line that confuses me.
Can someone please clarify?
It's because
[tex]
0 \leq e^{5z_{n}}\frac{|x|^{n+1}}{(n+1)!} \leq e^{0}\frac{|x|^{n+1}}{(n+1)!}
[/tex]
The maximum value of e^(5*z_n) for z_n in the interval [x,0] is at z_n=0. Where e^(5*z_n)=e^0=1. That's the largest value R_n could possibly have.
Dick said:
It's because
[tex]
[/tex]
Where did they get the less than or equal to signs? I don't understand where they're coming from.
Also, how do you know that,
[tex]e^{5z_{n}}\frac{|x|^{n+1}}{(n+1)!}[/tex] is indeed larger or equal to 0?
Is it because the minimum value for e^(5*z_n) for z_n in the interval [x,0] is at z_n = x. Where e^(5*z_n) = e^(5x) which is always less than zero because x < 0.
jegues said:
Where did they get the less than or equal to signs? I don't understand how they're just pulling that out of nowhere.
I put the less than or equal signs in. That part isn't very important. The point is just that (as you said) z_n is between x and 0. So 0<=exp(5*z_n)<=1. So |R_n| is bounded below by zero and above by the expression replacing exp(5*z_n) with 1. And yes, again. The value of the upper limit goes to 0 as n->infinity.
You want a bound for |R_n|. An absolute value is always >=0. And z_n is in [x,0]. And exp(z_n) is never negative. Are you trying to make this confusing?
No I'm not trying to make this confusing, I'm trying to understand it. Didn't you get things wrong when you were learning?
My concern is that I've been doing problems and I always have trouble proving that,
[tex]lim_{n \rightarrow \infty} R_{n} = 0[/tex]
In order to do this I need to make use of the squeeze theorem, and in order for me to use squeeze theorem I have to be able to assign the correct boundaries around [tex] R_{n} [/tex] for a given range of x. (i.e. x < 0)
I'm trying to understand this so I can consistently show that either [tex]lim_{n \rightarrow \infty} R_{n} = 0[/tex] or not.
Sure, I got things wrong when learning. But this seems to be getting more confusing. If you can show |R_n|->0, then you have automatically shown R_n->0. You don't need a 'correct lower bound' for |R_n|. 0 will work just fine. Worry about the upper bound. Show that goes to 0.
Okay I'm going to give this another shot.
Case 1: x < 0
So, [tex] 0 > z_{n} > x[/tex]
Since,
[tex]|R_{n}| = 5^{n+1}e^{5z_{n}}\frac{|x|^{n+1}}{(n+1)!}[/tex]
We can see that in the range [tex]0 > z_{n} > x[/tex] the largest value we can obtain for [tex]e^{5z_{n}}[/tex] will be obtained when we set [tex]z_{n} = 0[/tex].
We can see that,
[tex] 0 \leq |R_{n}| \leq 5^{n+1} \frac{|x|^{n+1}}{(n+1)!} [/tex]
[tex] 0 \leq 5^{n+1}e^{5z_{n}}\frac{|x|^{n+1}}{(n+1)!} \leq 5^{n+1} \frac{|x|^{n+1}}{(n+1)!} [/tex]
Dividing all terms by [tex]5^{n+1}[/tex] ***NOTE: This step I'm not too sure about. I need to get the [tex]5^{n+1}[/tex] terms out so when I take the limit of,
[tex]5^{n+1} \frac{|x|^{n+1}}{(n+1)!}[/tex] as [tex]n \rightarrow \infty[/tex]
I will get 0. With the [tex]5^{n+1}[/tex] term there I'll get [tex]\infty \cdot 0[/tex]
EDIT: I am able to simply state that,
[tex]lim_{n \rightarrow \infty}5^{n+1} \frac{|x|^{n+1}}{(n+1)!} = 0[/tex] ?
How is this justified? (This is what the given solution states)
Plowing on...
[tex] 0 \leq e^{5z_{n}}\frac{|x|^{n+1}}{(n+1)!} \leq \frac{|x|^{n+1}}{(n+1)!} [/tex]
Applying squeeze theorem,
EDIT: Now that I think about it, since I removed the, [tex]5^{n+1}[/tex] term it isn't really, [tex]|R_{n}|[/tex] anymore because that term's not there, right? So how do we deal with this?
[tex]lim_{n \rightarrow \infty} 0 \leq lim_{n \rightarrow \infty} |R_{n}| \leq lim_{n \rightarrow \infty} \frac{|x|^{n+1}}{(n+1)!} }[/tex]
We can see that,
[tex]lim_{n \rightarrow \infty} 0 = lim_{n \rightarrow \infty} \frac{|x|^{n+1}}{(n+1)!} } = 0[/tex]
Therefore we can conclude that,
[tex]lim_{n \rightarrow \infty} |R_{n}| = 0[/tex]
So,
[tex]lim_{n \rightarrow \infty} R_{n} = 0[/tex] for all x < 0.
How does this look? Again, there's that one annoying [tex]5^{n+1}[/tex] I'm not sure how to get rid of in there, but other than that everything seems to make sense. After I figure that part out I'll move on to case 2: x > 0.
DON'T divide by 5^(n+1). You've got
[tex]
[/tex]
NOW do the squeeze by showing lim n->infinity |5*x|^(n+1)/(n+1)! is zero. If you can show the limit of |x|^(n+1)/(n+1)! zero you can surely show the limit of |5*x|^(n+1)/(n+1)! is zero.
[tex]
[/tex]
So my task it to show that,
[tex]lim_{n \rightarrow \infty}\frac{|5x|^{n+1}}{(n+1)!} = 0[/tex]
Well we can do the following,
Let [tex]y = 5x[/tex].
Now surely it's trivial to see that,
[tex]lim_{n \rightarrow \infty}\frac{|y|^{n+1}}{(n+1)!} = 0[/tex]
In fact, now that I think about it, it was trivial to see that simply,
Is true, no?
I want to make sure what I'm doing is justified and I'm not just assuming the limit as n goes to infinity is 0.
Is this correct, do I need to show anything more? (As far as this limit is concerned)
Is true, no?
Unless you've already proved it in the course, it probably wouldn't hurt to say why you think lim n->infinity |y|^(n+1)/(n+1)!=0 for all y. You seem pretty confident. And it's certainly true. Why do you think so?
We did prove it in class. Our professor said we can simply use it as a tool at our disposale without justification.
So I should be okay stating,
for all x < 0.
If that's okay I'm going to move on to case 2: x > 0 in my next post.
for all x < 0.
Why wouldn't it be ok? If it's true for all y, then it's true for y=5x. Good idea to move on.
Case 2: x > 0
So,
[tex]0 < z_{n} < x[/tex]
Since,
We can see that in the range [tex]0 < z_{n} < x[/tex] the largest value we can obtain for [tex]e^{5z_{n}}[/tex] is when [tex]z_{n} = x[/tex].
So we can see that,
[tex] 0 \leq |R_{n}| \leq 5^{n+1} e^{5x} \frac{|x|^{n+1}}{(n+1)!} [/tex]
[tex]lim_{n \rightarrow \infty} 0 \leq lim_{n \rightarrow \infty} |R_{n}| \leq e^{5x} lim_{n \rightarrow \infty} \frac{|5x|^{n+1}}{(n+1)!} }[/tex]
Since,
[tex]lim_{n \rightarrow \infty} 0 = e^{5x} lim_{n \rightarrow \infty} \frac{|5x|^{n+1}}{(n+1)!} } = 0[/tex]
Therefore,
and it follows that,
[tex]lim_{n \rightarrow \infty} R_{n} = 0[/tex] [tex]\forall x[/tex]
Since we've examined both cases.
How's this look?
What is Taylors Remainder Confusion?
Taylors Remainder Confusion is a mathematical concept that deals with approximating functions using polynomials.
How is Taylors Remainder Confusion different from regular Taylor series?
Taylors Remainder Confusion takes into account the error in the approximation, whereas regular Taylor series only looks at the polynomial approximation itself.
Why is Taylors Remainder Confusion important?
Taylors Remainder Confusion allows us to get a better understanding of the accuracy of our polynomial approximations, which is important in various fields of science and engineering.
How is Taylors Remainder Confusion calculated?
Taylors Remainder Confusion is calculated using the Lagrange remainder formula, which takes into account the error term in the Taylor polynomial approximation.
What are some real-life applications of Taylors Remainder Confusion?
Taylors Remainder Confusion is used in fields such as physics, engineering, and economics to approximate functions and make predictions with a known level of error. It is also used in computer science to analyze the accuracy and efficiency of algorithms.
