Temporal and Spatial Coherence
  • Thread starter Thread starter elemis
    Coherence
Coherence is a statistical measure of phase that indicates how well the phase of a wave at one point in space-time can predict the phase at another point. Perfect temporal coherence allows for precise phase determination at different times, while perfect spatial coherence enables this at different positions. Incoherent waves provide no predictive power regarding phase at other times or locations. Partially coherent waves offer some predictability based on their degree of coherence. The relationship between temporal and spatial coherence varies depending on the direction of wave propagation.
elemis
What is the difference between the two in simple terms ?
The thing to keep in mind is that coherence is a statistical measure of phase. Specifically, if I know the phase at some point in space-time, coherence determines how precisely the phase at some other point in space-time is known. For example;
If I know the phase of a wave at time, t1 and position x1;
- if the wave is perfectly temporally coherent then I can precisely determine the phase of a wave at time t2 and position x1.
- if the wave is perfectly spatially coherent then I can precisely determine the phase of a wave at time t1 and position x2.
- For a perfectly incoherent wave, the phase at t1 and x1 tells me nothing about the phase at different times and in different points in space.
- For partially coherent waves, I can determine the phase at different times and positions within a precision determined by the degree of (temporal and spatial) coherence.
Note too that;
- If the x-direction is parallel to the direction of wave propagation then temporal and spatial coherence are linked via c = x/t.
- If the x-direction is perpendicular to the direction of wave propagation then the temporal and spatial coherence are independent. That is, a wave can be simultaneously spatially coherent and temporally incoherent (and vice-versa).
Claude.
Thread 'Question about pressure of a liquid'
I am looking at pressure in liquids and I am testing my idea. The vertical tube is 100m, the contraption is filled with water. The vertical tube is very thin(maybe 1mm^2 cross section). The area of the base is ~100m^2. Will he top half be launched in the air if suddenly it cracked?- assuming its light enough. I want to test my idea that if I had a thin long ruber tube that I lifted up, then the pressure at "red lines" will be high and that the $force = pressure * area$ would be massive...
I feel it should be solvable we just need to find a perfect pattern, and there will be a general pattern since the forces acting are based on a single function, so..... you can't actually say it is unsolvable right? Cause imaging 3 bodies actually existed somwhere in this universe then nature isn't gonna wait till we predict it! And yea I have checked in many places that tiny changes cause large changes so it becomes chaos........ but still I just can't accept that it is impossible to solve...
