Temporarily powering 5.5v board from 2.5v ethernet cable
  • Thread starter Thread starter kzgrey
    Board Cable
Charging a capacitor from a 2.5v Ethernet line to power a circuit at 5.5v is feasible, provided the current draw is minimal. The charging process will block Ethernet traffic, but this can be mitigated by using a filter, such as an RF choke, to isolate the data signal. The circuit design should consider the specifications of the capacitor and the duration of power needed for the Atmel chip and I2C sensor. Exploring the Power over Ethernet (PoE) standard may provide additional insights or solutions. Commercial adapters are available for easier implementation of power extraction from Ethernet cables.
kzgrey
I'm not an EE. I'm a Software Engineer.
I would like to build a small circuit that would leach power from an active 2.5v Ethernet line to charge a capacitor very slowly (over a timespan of 1-2 minutes). When the capacitor is fully charged, it would then discharge at 5.5v to power a circuit containing an Atmel chip and an I2C sensor.
Q1) Is this possible?
Q2) Would charging the capacitor block traffic over the Ethernet cable?
Q3) Can anyone give me a rough idea what this circuit should look like and what the specs of the capacitor should be?
Alternatively, can someone refer me to an EE who could design this for me?
Probably, providing your circuit doesn't draw much current. (To supply 10mA at 5.5V may equate to taking, say, 30mA from the Ethernet.)
It's not clear for how long you wish to power your circuit, but I assume its for some minutes, at least?
It would, but this could probably be prevented by incorporating a filter to block that data signal. An RF choke built around a ferrite core should do the job, allowing the DC through but isolating your circuit from the digital data on the line.
Beyond this general discussion, I can't help much though.
Have you looked at the PoE standard?
http://en.wikipedia.org/wiki/Power_over_Ethernet
There are commercial plug and play adaptors designed to inject and extract the power from standard Ethernet cable. You can also build the circuit into your device if you don't want a physically separate unit.
Hi all I have some confusion about piezoelectrical sensors combination. If i have three acoustic piezoelectrical sensors (with same receive sensitivity in dB ref V/1uPa) placed at specific distance, these sensors receive acoustic signal from a sound source placed at far field distance (Plane Wave) and from broadside. I receive output of these sensors through individual preamplifiers, add them through hardware like summer circuit adder or in software after digitization and in this way got an...
While I was rolling out a shielded cable, a though came to my mind - what happens to the current flow in the cable if there came a short between the wire and the shield in both ends of the cable? For simplicity, lets assume a 1-wire copper wire wrapped in an aluminum shield. The wire and the shield has the same cross section area. There are insulating material between them, and in both ends there is a short between them. My first thought, the total resistance of the cable would be reduced...
I am not an electrical engineering student, but a lowly apprentice electrician. I learn both on the job and also take classes for my apprenticeship. I recently wired my first transformer and I understand that the neutral and ground are bonded together in the transformer or in the service. What I don't understand is, if the neutral is a current carrying conductor, which is then bonded to the ground conductor, why does current only flow back to its source and not on the ground path...
