What is the tension and velocity in a rope attached to a moving space station?
The discussion revolves around calculating the tension in a rope and the velocity of a person attached to a space station moving at 25,000 km/h. The participant is uncertain about which acceleration to use for the tension formula and how to determine their velocity concerning the space station. Key points include the need to consider the direction of movement relative to Earth and the potential irrelevance of certain details provided in the problem. The conversation emphasizes the importance of identifying relevant information to simplify the calculations. Overall, the problem presents challenges but may be more straightforward than initially perceived.
elf197320501
You're attached to a space station moving at 25000 km/h at a distance of 500 km above Earth by a rope connected to a jetpack(force 3N). Your mass is 60kg. Using the jetpack you move to the maximum extension of the rope (6m) and activate the jetpack for 3s perpendicular to the rope. What is the tension in the rope and your velocity with respect to the point of attachment on the station?
I know that the equation for tension is FT=m(g+a) but I'm not sure about which acceleration to use (acceleration of the space station a=v^2/r where 'v' is 25000km/h and 'r' is 500km+distance from earth, or whether to find the acceleration by v=d/t & a=v/t where 'd' is the max extension of the rope and 't'=3s) and I'm not really sure about the velocity with respect to the point of attachment (would it just be v=d/t?)
Any help would be greatly appreciated
This problem seems to be lacking information. Yes, you move to the maximum extension of the rope, but in what direction relative to the center of the Earth?
That is not general enough to be worth remembering. It only applies for a vertical acceleration. Never memorise a formula if you do not also memorise the circumstances in which it applies.
In the present problem, you have been given all sorts of largely irrelevant detail. E.g., for a completely accurate answer you would need to know the mass of the space station, but you do not. Much that is given is of lesser relevance. Your first challenge is to figure out what matters.
Please post some thoughts on that.
The problem may well be easier than you think.
