Tension Calculations for Hanging a Sign at a 30° Angle | Homework Help
  • Thread starter Thread starter liz155
    Homework Tension
To solve for the tension in cables supporting a 775 N sign at a 30° angle, start by drawing a Free Body Diagram. Sum the forces in the x and y directions, ensuring that the components equal zero due to equilibrium. Use the equations Fx = Fsin(theta) and Fy = Fcos(theta) to express the forces in terms of tension. Substitute known values, including the weight of the sign and the angle, to find the tensions in the cables. The discussion concludes with the user successfully finding the correct answer after following the guidance provided.
liz155
Joe wishes to hang a sign weighing 775 N so that cable A attached to the store makes a 30.0° angle, as shown in Figure 7-16. Cable B is horizontal and attached to an adjoining building.
I have no idea where to start. Thanks for any help. :-)
--Cori
Draw a Free Body Diagram and then begin with summing the forces in the x and y directions, and possibly taking a moment too.
Sorry, I still don't understand. Could you maybe explain in more detail? I attached a picture of the diagram in my book if that helps. :-)
Since the sign is in equilibrium the sum of the components of the forces need to be zero.
Can you set the two equations up for the horizontal and vertical components of the forces? I assume that you need to determine the tensions in the cables.
What are you solving for specifically? Are you looking for tension in the cables. If so, I believe you can probably start with something like this:
Do you free body diagram and for the equations consider the ones below:
Fx=Fsin(theta)
Fy=Fcos(theta)
I believe since you know the sign is 775N you have a starting point there. You can start with cable A and substitute what you know for A in place of F. You already have Theta (the angle). This should get you going.
Thanks for all the help everyone! I finally got the answer, and when I checked with my teacher... it was right!
Thanks!
