What is the general approach for calculating tension in different situations?
  • Context: Graduate
  • Thread starter Thread starter ShakyAsh
    Ring Rotating Tension
4 replies · 12K views
ShakyAsh
Hello people,
So i found out the tension in a ring rotating with constant angular velocity (in gravity free space)
Considering a small element of mass dm - tension will provide the centripetal force,
2Tsin(dθ/2) = dmrω^2
sindθ ≈ dθ
dm = m/2πr ds
ds = rdθ
T = (mrω^2)/2πNow, the other method
K.E. = K = 1/2 Iω^2 = 1/2 mr^2 ω^2
If we increase the radius from r to r+dr, then work done by tension
dW = T d(2πr) = dK
T = 1/2π dK/dr
T = (mrω^2)/2πEven though i get the same result, i have a doubt whether the second method is correct
I know that F=-dU/dr , but whether T=dK/ds , i don't know
Also, i want to know the general approach of calculating tension in situations like electro-magnetic fields, rotation & all.
Regards
ShakyAsh said:
2Tsin(dθ/2) = dmωr^2
Typo: you mean dmrω^2
K.E.= K = 1/2 Iω^2 = 1/2 mr^2 ω^2
dW = T d(2πr) = dK
T = 1/2π dK/dr
T = (mrω^2)/2π
I can't think of a justification for that method. Can you describe your reasoning here?
Yeah dmrω^2 , sorry
As i said, if radius of the ring is increased by dr, then work done by the tangential force tension will be T*(change in circumference) which will be equal to the change in kinetic energy which in this case is the rotational energy.
Yes, the approach is valid. If you have doubts, you can replace the ring by N discrete points with tension T between them and derive dW=T ds for N->Inf.
Dividing it into N discrete points, why didn't i think of that?
Anyways, thank you very much.
I think i understand it now.
