Tension of a rope holing a mass on an inclined plane
The discussion revolves around calculating the tension in a string connecting two blocks on a frictionless inclined plane, with given masses M1 = 52.0 kg and M2 = 30.0 kg, and an incline angle of 11°. The user initially attempts to apply Newton's second law (F=ma) but struggles with the forces involved, particularly the normal and gravitational forces. Clarification is sought regarding the orientation of the masses—whether they are hanging vertically or lying on the incline. The user indicates that both masses are connected by a rope on the incline at an angle of 11 degrees. This setup requires a proper analysis of forces to accurately determine the tension in the string.
Rasine
Two blocks are connected by a massless string and are held in position by another massless string along a frictionless incline (as shown in the figure). Let M1 = 52.0 kg, M2 = 30.0 kg, and q = 11°. Calculate the tension in the string connecting the two blocks.
so..first i am going to use f=ma
the forces that need to be taken into acount is the weight and noraml force..so i have Fn+w=ma, but the boxes are stationary so the a=0
then i have Fn+w=0...so w=mg so now i have Fn+mg=0
i find Fn=-15288 N which is on the y-axis of my free-body diagram and then i try to solve for the x component on the digram using 11 deg and Fn...tan 11deg=15288/x
but that is not the right approch...please help me
Your post is totally unclear:
1. Are your masses HANGING vertically?
2. Are both your masses lying on the incline?
3. Or is one of the masses hanging, the other lying on the incline?
both of the masses are conncected by a rope on an inclined plane with a 11 deg agnle from the horizontal ground
Thread 'Collision of a bullet on a rod-string system: query'
In this question, I have a question. I am NOT trying to solve it, but it is just a conceptual question. Consider the point on the rod, which connects the string and the rod. My question: just before and after the collision, is ANGULAR momentum CONSERVED about this point? Lets call the point which connects the string and rod as P. Why am I asking this? : it is clear from the scenario that the point of concern, which connects the string and the rod, moves in a circular path due to the string...
