Tension of two strings with centripetal acceleration?
A 4.00 kg object rotates horizontally at a speed of 6.00 m/s, with two strings providing tension. The radius of rotation is calculated to be approximately 1.32 m, leading to a centripetal acceleration of 27.21 m/s². The equations for net forces in both the x and y directions are established, but the user struggles to derive the correct tensions (T1 and T2), initially calculating T1 as 102.20 N and T2 as 42.94 N, while the expected answers are 109 N and 56.4 N. The user realizes the error was due to using the wrong angle in their calculations. After correcting this mistake, they express gratitude for the assistance received.
Elenor
1. Homework Statement :
A 4.00 kg object is attached to a vertical rod by two strings (as below). The object rotates in a horizontal circle at constant speed 6.00 m/s.
mass = 4.00 kg
V = 6.00 m/s
centripetal acceleration = Ac
Ac = V^2/r
<br /> \vec{F}_{net} = \Sigma \vec{F} = m \vec{a}<br />
mass = 4.00 kg
V = 6.00 m/s
Using trig, the radius (r) = 1.3229m
The lower angle of the top triangle (composed of the half the length of the rod, the length of the string, and the radius) should be 48.5904 degrees. The upper angle would then be 41.4096 degrees.
Using (Ac = V^2/r): (6.00m/s)^2/1.3229m = Ac = 27.2129m/s^2
T1 is the upper string, and
T2 in the lower string.
g = 9.8 m/(s^2)
Here is my main concern--do I have the following two equations right?
<br /> (\vec{F}_{net})_x = \Sigma F_x = 0<br /> = m(Ac) - T1cos(41.4096) - T2cos(41.4096)
<br /> (\vec{F}_{net})_x = \Sigma F_x = 0<br /> = T1sin(41.4096) - T2sin(41.4096) - mg
Therefore:
X direction: m(Ac) = T1cos(41.4096) + T2cos(41.4096)
and
Y direction: mg = T1sin(41.4096) - T2sin(41.4096)
At this point I have all the values except T1 and T2, so I can solve for them . . .
T1 = [m(Ac) - T2cos(41.4096)]/cos(41.4096)
mg = {[m(Ac) - T2cos(41.4096)]/cos(41.4096)} sin(41.4096) - T2sin(41.4096)
mg = m(Ac)[sin(41.4096)]/cos(41.4096) - T2sin(41.4096) - T2sin(41.4096)
-mg + m(Ac)[sin(41.4096)]/cos(41.4096) = T2[sin(41.4096) + sin(41.4096)]
{m(Ac) sin(41.4096)/cos(41.4096) - mg} / 2sin(41.4096)] = T2
T2 = 42.9353N
And . . . using that value of T2, T1 = 102.2001N
Now, I've resorted to working the problem with these numbers, as I have an answer to the problems with these numbers . . . and my problem is that this is not right, and I can't figure out where I went wrong.
With these numbers, I know that the correct answers are: T1 = 109N and T2 = 56.4N
When I figure out what I'm doing wrong, and how to do it right . . . I'll switch to the other set of numbers, for my problem.
Is my method correct? Frequently my problems are due to some little think like forgetting to square something . . . If that's all it is, I'm sorry to bother you guys with it. However, I'll be glad for any help you can give me with this problem! Thank you very much!
Please let me know if there's something I should clarify. :-)
I'm not sure how to mark this solved, but at any rate, I've finally figured it out. :-) I was simply using the wrong angle. :o Oh well . . . at least I had it mostly right . . . ;)
Seems like a question from MDHS >_> =)
MDHS? Would that be one of these:
MDHS Mississippi Department of Human Services
MDHS Methods for the Determination of Hazardous Substances (United Kingdom)
MDHS Mater Dei High School (Santa Ana, CA)
MDHS McDonnell Douglas Helicopter Systems
MDHS Markham District High School (Canada)
MDHS Monsignor Donovan High School (Ocean County, NJ)
MDHS Milton District High School (Canada)
MDHS Mount Dora High School (Lake County, FL)
(http://acronyms.thefreedictionary.com/MDHS)
Or something else entirely?
that would be
:smile:
had the same sort of question on my assignment.
Thread 'Collision of a bullet on a rod-string system: query'
In this question, I have a question. I am NOT trying to solve it, but it is just a conceptual question. Consider the point on the rod, which connects the string and the rod. My question: just before and after the collision, is ANGULAR momentum CONSERVED about this point? Lets call the point which connects the string and rod as P. Why am I asking this? : it is clear from the scenario that the point of concern, which connects the string and the rod, moves in a circular path due to the string...
Thread 'A cylinder connected to a hanged mass'
Let's declare that for the cylinder, mass = M = 10 kg Radius = R = 4 m For the wall and the floor, Friction coeff = ##\mu## = 0.5 For the hanging mass, mass = m = 11 kg First, we divide the force according to their respective plane (x and y thing, correct me if I'm wrong) and according to which, cylinder or the hanging mass, they're working on. Force on the hanging mass $$mg - T = ma$$ Force(Cylinder) on y $$N_f + f_w - Mg = 0$$ Force(Cylinder) on x $$T + f_f - N_w = Ma$$ There's also...
