Tension on a rope - not a homework question
To calculate the tension on a rope tethering a boat, one must consider the angles at which the rope is positioned, as this affects the tension experienced by the rope. The maximum force exerted by the wind on the boat is 3000 pounds, which is below the rope's capacity of 8000 pounds, indicating that the rope can safely hold the boat under these conditions. The boat's stationary position versus movement due to wind can influence the tension; moving boats may experience dynamic forces that increase tension. A sketch illustrating the angles and forces involved would enhance understanding of the problem. Proper analysis of these factors is essential for ensuring safety and effectiveness in tethering the boat.
zulfiqar6
My boat is tethered to a rope that can withstand a maximum of 8000 pounds of tension. The wind will exert, at maximum, 3000 pounds of force on the boat. How do I calculate the tension on the rope based on the angles that the rope is at? does it make a difference if the boat is stationary, or if the wind is causing it to move? Thanks for the help (:
Can you add a sketch? That would help to understand the problem.
Even if it is not homework, it could be homework-like, so it could fit better to our homework section.
The rope is tied into the person (the load of 200 pounds) and the rope goes up from the person to a fixed pulley and back down to his hands. He hauls the rope to suspend himself in the air. What is the mechanical advantage of the system? The person will indeed only have to lift half of his body weight (roughly 100 pounds) because he now lessened the load by that same amount. This APPEARS to be a 2:1 because he can hold himself with half the force, but my question is: is that mechanical...
Hello everyone, Consider the problem in which a car is told to travel at 30 km/h for L kilometers and then at 60 km/h for another L kilometers. Next, you are asked to determine the average speed. My question is: although we know that the average speed in this case is the harmonic mean of the two speeds, is it also possible to state that the average speed over this 2L-kilometer stretch can be obtained as a weighted average of the two speeds? Best regards, DaTario
Some physics textbook writer told me that Newton's first law applies only on bodies that feel no interactions at all. He said that if a body is on rest or moves in constant velocity, there is no external force acting on it. But I have heard another form of the law that says the net force acting on a body must be zero. This means there is interactions involved after all. So which one is correct?
