nov0798
- 2
Hi gang. I need some help with a technical issue.
I am an avid mountain biker, and one of the forums I post on has an ongoing discussion of whether or not the bottom spokes in a bicycle wheel support the load, or the upper spokes support the load.
In a typical wheel the spokes are tensioned, sometimes up to 350 lbs of tension per spoke in high end wheels, with up to 36 spokes per wheel. All the spokes attach at a center hub/flange. One group believes that the load is supported by the top spokes, while the other group believes that the load is supported by the bottom spokes.
Numerous tests have been done using a tensiometer on the spokes showing that the bottom spokes tension reduces when a riders weight is applied, however the top spokes show no change in tension. It would leave me to believe which I do, that the spokes showing the change in tension are the ones carrying the load. In addition, it is my belief that the spokes act as a rigid column as long as they remain under tension, at which point they carry the load.
One of the issues we are having is that some cannot understand how a nipple on the rim side of the spoke (tensioning end), since it is not affixed to a solid structure could remain in place under a compressive load (rider weight).
So bottom line is I need some folks smarter than me in the physics would to easily explain how this works. I would love to actually build a model in which I tension a single spoke, and then stand on it. the issue I am having is how would I create a fixture that would allow me to do this since neither end is really supported?
Any help would be GREATLY appreciated.
Thanks
Brian
Thanks
Brian
