MHB How many spheres are in a tetrahedral stack and what is its height?
  • Thread starter Thread starter MarkFL
    Spheres
In a tetrahedral stack of spheres with $n$ layers and diameter $d$, the total number of spheres, $N$, is given by the formula $N = \frac{n(n+1)(n+2)}{6}$, which can also be expressed as the binomial coefficient $\binom{n+2}{3}$. The height $h$ of the stack is calculated as $h = \sqrt{\frac{2}{3}}(n-1)d + d$, accounting for both the upper and lower parts of the spheres. The discussion includes attempts to derive these formulas and suggestions for clearer notation in mathematical expressions. The calculations and reasoning provided demonstrate a solid understanding of the geometric relationships in the tetrahedral arrangement.
MarkFL
MHB
Consider a tetrahedral stack of spheres as in this image:
Suppose there is a stack consisting of $n$ layers, and the spheres all have diameter $d$.
Showing your work:
a) Compute the number $N$ of spheres in the stack as a function of $n$. Then, express $N$ as a binomial coefficient.
b) Compute the height $h$ of the stack as a function of $d$ and $n$.
Mathematics news on Phys.org
b)My attempt on '$$b$$':
Tetrahedron formed is of side $$(n-1).d$$ .The vertex $$A$$(center of upper sphere),centroid of triangle formed by lower spheres $$G$$ and one of lower vertices B(or C or D) forms right angled triangle.
$$\begin{align*}\text{AG}=\text{height}&=\sqrt{(\text{AB})^2-(\text{BG})^2}\\&=\sqrt{(n-1)^{2}.d^{2}-\frac{(n-1)^{2}.{d}^2}{3}}\\&=\sqrt{\frac{2}{3}}(n-1)d\end{align*}$$
mathworker said:
b)My attempt on 'b':
Tetrahedron formed is of side $$(n-1).d$$ .The vertex A(center of upper sphere),centroid of triangle formed by lower spheres G and one of lower vertices B(or C or D) forms right angled triangle.
You are close...but you have left out something.
$$\sqrt{\frac{2}{3}}(n-1)d+d$$?(adding the upper and lower part of spheres)
Yes, that is correct...well done! (Sun)
a)counting from each layer,
total number of spheres is,
$$\sum_{n=1}^n \frac{n(n+1)}{2}=\frac{n(n+1)(n+2)}{6}=\binom{n+2}{3} $$
I would avoid using the same variable for both the index of summation and the upper limit; I would write instead:
$$\sum_{k=1}^n \frac{k(k+1)}{2}=\frac{n(n+1)(n+2)}{6}=\binom{n+2}{3} $$
May I ask how you determined the partial sum? (Wink)
$$\begin{align*}\sum\frac{n(n+1)}{2}&=\frac{1}{2}(\sum_n^2)+\sum n)\\&=\frac{1}{2}\left(\left(\frac{(n(n+1)(2n+1)}{6}\right)+\left(\frac{n(n+1)}{2}\right)\right)\\&=\frac{n(n+1)}{4}.\left(\frac{2n+1}{3}+1\right)\\&=\frac{n(n+1)(n+2)}{6}\end{align*}$$
Here is my solution:
a) First, we want to compute the number of spheres $S_k$ in the $k$ layer (where $1\le k\le n$), counting from the top. Each layer is a triangular grid of spheres with $k$ rows, and we may use the difference equation:
$$S_{j}-S_{j-1}=j$$ where $$S_{1}=1$$ and $$1\le j\le k$$
The homogeneous solution is:
$$h_j=c_1$$
and we should then expect to find a particular solution of the form:
$$p_j=Aj^2+Bj$$
Substituting this particular solution into the difference equation, we find:
$$\left(Aj^2+Bj \right)-\left(A(j-1)^2+B(j-1) \right)=j$$
$$2Aj-(A-B)=j-0$$
Equating coefficients, we find:
$$2A=1\,\therefore\,A=\frac{1}{2}$$
$$A-B=0\,\therefore\,B=A=\frac{1}{2}$$
Hence:
$$p_j=\frac{1}{2}j^2+\frac{1}{2}j=\frac{j(j+1)}{2}$$
Thus, the general solution is:
$$S_{j}=h_j+p_j=c_1+\frac{j(j+1)}{2}$$
Now we may determine the parameter:
$$S_{1}=c_1+\frac{1(1+1)}{2}=c_1+1=1\,\therefore\,c_1=0$$
Thus, the solution satisfying the given conditions is:
$$S_{j}=\frac{j(j+1)}{2}$$
This number is referred to as the $n$th triangular number, and may be written as a binomial coefficient:
$$t_n=\frac{n(n+1)}{2}=\frac{(n+1)!}{2!((n+1)-2)!}={n+1 \choose 2}$$
Now, we want to find the sum of the spheres in all the layers, thus we may use the difference equation:
$$T_{k}-T_{k-1}=\frac{k(k+1)}{2}$$ where $$T_1=1$$ and $$1\le k\le n$$
$$h_k=c_1$$
and we should expect a particular solution of the form:
$$p_k=Ak^3+Bk^2+Ck$$
$$\left(Ak^3+Bk^2+Ck \right)-\left(A(k-1)^3+B(k-1)^2+C(k-1) \right)=\frac{1}{2}k^2+\frac{1}{2}k$$
$$3Ak^2+(-3A+2B)k+(A-B+C)=\frac{1}{2}k^2+\frac{1}{2}k+0$$
$$3A=\frac{1}{2}\,\therefore\,A=\frac{1}{6}$$
$$-3A+2B=\frac{1}{2}\,\therefore\,B=\frac{1}{2}$$
$$A-B+C=0\,\therefore\,C=\frac{1}{3}$$
And so we have:
$$p_k=\frac{1}{6}k^3+\frac{1}{2}k^2+\frac{1}{3}k= \frac{k^3+3k^2+2k}{6}= \frac{k(k+1)(k+2)}{6}$$
$$T_k=h_k+p_k=c_1+\frac{k(k+1)(k+2)}{6}$$
$$T_1=c_1+\frac{1(1+1)(1+2)}{6}=c_1+1=1\,\therefore\,c_1=0$$
$$T_k=\frac{k(k+1)(k+2)}{6}$$
And so, we may state:
$$N=T_n=\frac{n(n+1)(n+2)}{6}=\frac{(n+2)!}{3!((n+2)-3)!}={n+2 \choose 3}$$
This number is referred to as the $n$th tetrahedral number, or triangular pyramidal number.
b) To find the height of the stack, consider connecting the centers of the 4 spheres at each vertex with a line segment, each of length $(n-1)d$.
Now, to find the height $h_T$ of the resulting tetrahedron, we may drop a vertical line segment from the apex to the base and label its length $h_T$. Next draw a line segment from the apex down one of its faces bisecting the face, and we find its length $\ell$ from $$\sin\left(60^{\circ} \right)=\frac{\ell}{(n-1)d}\,\therefore\,\ell=\frac{\sqrt{3}}{2}(n-1)d$$.
Now, observing that the vertical line $h_T$ intersects the base in the middle (the point equidistant from the 3 vertices), we can find the length of the line segment $b$ joining $h_T$ and $\ell$ by dividing the equilateral base into 3 congruent isosceles triangles each of which has an area $$\frac{1}{3}$$ that of the equilateral base:
$$\frac{1}{2}b(n-1)d=\frac{1}{3}\cdot\frac{1}{2}\sin\left(60^{\circ} \right)((n-1)d)^2$$
$$ b=\frac{1}{3}\cdot\frac{\sqrt{3}}{2}(n-1)d=\frac{1}{2\sqrt{3}}(n-1)d$$
Now we have a right triangle whose legs are $h_T$ and $b$ and whose hypotenuse is $\ell$, thus from the Pythagorean theorem, we obtain:
$$h_T=\sqrt{\ell^2-b^2}=\sqrt{\left(\frac{\sqrt{3}}{2}(n-1)d \right)^2-\left(\frac{1}{2\sqrt{3}}(n-1)d \right)^2}$$
$$h_T=(n-1)d\sqrt{\frac{3}{4}-\frac{1}{12}}=(n-1)d\sqrt{\frac{2}{3}}$$
Now, observing that we need to add 1 more spherical diameter to account for the radii below and above the tetrahedron, we then may state:
$$h=h_T+d=(n-1)d\sqrt{\frac{2}{3}}+d=d\left((n-1)\sqrt{\frac{2}{3}}+1 \right)$$
