The Arrow of Time: Entropy & System Evolution
The discussion centers on the principle that systems evolve toward increased total entropy over time, as dictated by the second law of thermodynamics. Even if a specific part of a system, such as hot water, shows a decrease in entropy, the overall entropy of the system and its environment still increases due to larger entropy changes in other parts, like melting ice. The example illustrates that while the hot water's entropy decreases, the ice's entropy increase is greater, ensuring the total entropy remains positive. This concept emphasizes that local decreases in entropy do not violate thermodynamic laws, as they are compensated by greater increases elsewhere. Overall, the total entropy of a closed system and its environment always trends upward.
paco1955
it is the change in entropy that ultimately provides us with the answer to why systems will naturally evolve in one direction with time and not the other: systems always evolve in time in such a way that the total entropy of system + environment increases. If you observe a system in which the entropy appears to decrease, you can be sure that somewhere there is a change in the entropy of the environment large enough to make the total entropy change positive. for example, suppose that in a closed system i drop an ice cube in a container full of hot water. heat will flow from the hot water to the ice. the temperature of the hot water drops and the ice melts simultaneously until both bodies of water reach the same temperature and form a homogeneous luke-warm body of water. the cooling process of the hot water is a negative entropy change. in other words, the entropy of the hot water decreases. (the hot water changes from a relatively disorganized state to a more organized state.) the melting process of the ice is a positive entropy change. in other words, the entropy of the ice increases. (the ice changes from a relatively organized state to a more disorganized state.) it turns out that the positive entropy change of the ice is greater than the negative entropy change of the hot water. in other words, if you observe the hot water in which the entropy appears to decrease, you can be sure that there is a change in the entropy of the ice large enough to make the total entropy change positive. if "sh" is the negative entropy change of the hot water (sh < 0) and "si" is the positive entropy change of the ice (si > 0), then sh + si > 0.
That makes a lot of sense! So basically, the total entropy of the system and environment always increases, even if the entropy of one part of the system (like the hot water in this example) appears to decrease. This is because the entropy change in the other part of the system (like the ice in this example) is greater than the entropy change in the first part. Thank you for explaining this concept so clearly!
Thread 'Gauss' law seems to imply instantaneous electric field propagation'
Imagine a charged sphere at the origin connected through an open switch to a vertical grounded wire. We wish to find an expression for the horizontal component of the electric field at a distance ##\mathbf{r}## from the sphere as it discharges. By using the Lorenz gauge condition: $$\nabla \cdot \mathbf{A} + \frac{1}{c^2}\frac{\partial \phi}{\partial t}=0\tag{1}$$ we find the following retarded solutions to the Maxwell equations If we assume that...
Maxwell’s equations imply the following wave equation for the electric field $$\nabla^2\mathbf{E}-\frac{1}{c^2}\frac{\partial^2\mathbf{E}}{\partial t^2} = \frac{1}{\varepsilon_0}\nabla\rho+\mu_0\frac{\partial\mathbf J}{\partial t}.\tag{1}$$ I wonder if eqn.##(1)## can be split into the following transverse part $$\nabla^2\mathbf{E}_T-\frac{1}{c^2}\frac{\partial^2\mathbf{E}_T}{\partial t^2} = \mu_0\frac{\partial\mathbf{J}_T}{\partial t}\tag{2}$$ and longitudinal part...
Thread 'Recovering Hamilton's Equations from Poisson brackets'
The issue : Let me start by copying and pasting the relevant passage from the text, thanks to modern day methods of computing. The trouble is, in equation (4.79), it completely ignores the partial derivative of ##q_i## with respect to time, i.e. it puts ##\partial q_i/\partial t=0##. But ##q_i## is a dynamical variable of ##t##, or ##q_i(t)##. In the derivation of Hamilton's equations from the Hamiltonian, viz. ##H = p_i \dot q_i-L##, nowhere did we assume that ##\partial q_i/\partial...
