Bruno81
- 45
- 1
What is the consensus- Can the atom be considered a classical object if we managed to manipulate single atoms?
With technology getting better and finer, would not our instruments reveal that single atoms can in fact behave very very classical-like? Almost like bricks and walls?vanhees71 said:To the contrary, there's no way to understand matter in terms of its microscopic constituents in terms of a classical model. Classical physics is an approximation to quantum theory, valid for many-body systems.
Bruno81 said:What is the consensus- Can the atom be considered a classical object if we managed to manipulate single atoms?
That would depend on how classically you've been imagining them to act.Bruno81 said:Reading this got me thinking they can behave more classically than is imagined. No?
Bruno81 said:With technology getting better and finer, would not our instruments reveal that single atoms can in fact behave very very classical-like?
Thanks! Wouldn't the act of manipulation force the atom to be as classical as a shoe or a chair? I understand there are no classical objects which is even more mind boggling but I am trying to understand what can be achieved in terms of single atoms.Nugatory said:That would depend on how classically you've been imagining them to act.
Any massive particle has a quantum mechanical position operator and hence a property that is more or less well approximated by the classical notion of position. In the experiment you cite, the "more or less" is more "more" than in some other experiments, but the classical picture is still an approximation. Whether it's a good enough approximation to justify the claim "the atom can be considered a classical object" depends on what you're trying to do with it.
It's worth pointing out that when the first sentence of an article reads "Like a diner spearing a morsel of food with the tine of a fork..." you should not be expecting a lot of precision in the subsequent discussion. Analogies are OK, but you have to remember that they're analogies not the real thing.
[Edit: I should add that I'm using a lot more words to say the same thing vanadium50 said above]
Bruno81 said:Thanks! Wouldn't the act of manipulation force the atom to be as classical as a shoe or a chair?
Bruno81 said:But aren't you starting out with the premise that you want to prove - "Manipulation is a technique for putting quantum systems"...?
By doing what the article describes... Push the probe against the substrate to dislodge an atom and encourage it to bind to the tip of the probe, then move the probe around. The interactions needed to make that be lifting and pushing are completely quantum mechanical in nature.And if true, how would the researches lift/push a single atom?
