The average and variance of distributions (thermodynamics)
The discussion centers on calculating the average and variance of the Maxwell-Boltzmann distribution in thermodynamics. The average is correctly identified as the integral of x multiplied by the distribution function f(x), while the variance formula provided initially contains an error; it should include f(x) in the integral. The appropriate interval for integration is the entire real line, which is necessary to obtain meaningful results. The variance is determined to be 1/2b, with the constant a ensuring that the integral of f(x) equals 1. Clarifications on these points significantly aided the original poster's understanding.
pitch-black
(Note: I'm not sure about international notations or terms, but I hope everything is comprehensible)
Next Monday I will pass my exam in theoretical physics about thermodynamics.
However, there's still one thing that I couldn't find explicitly described in my lecture notes or any additional literature.
It's the average and variance of distributions. All I found was the formulas, but no further explications.
Average:
<x> = integral (x * f(x)) dx
Variance:
< (x - <x>)^2 > = integral (x * (x - <x>)^2) dx
f(x) is in this case the Maxwell-Boltzmann distribution (such as f(x) = a * exp(-b*x^2) ).
What I don't know is what interval do I have to choose?
I thought about the whole set of real numbers, so from negative infinity to positive. However doing so, I don't get a sensible result, it's zero.
I also have thought about [0; infinity] or [0; x], but I actually have no idea.
Is the end result a term (including x) or a constant?
Any hints are highly appreciated.
Science news on Phys.org
Average:
Variance:
For the f(x) you described, the mean is 0.
Your variance formula has an error. It should read:
< (x - <x>)^2 > = integral (f(x) * (x - <x>)^2) dx
The variance = 1/2b, a is needed so that the integral of f(x)=1.
The integral is over the entire real line.
Thank you!
That helped me a lot!
I need to calculate the amount of water condensed from a DX cooling coil per hour given the size of the expansion coil (the total condensing surface area), the incoming air temperature, the amount of air flow from the fan, the BTU capacity of the compressor and the incoming air humidity. There are lots of condenser calculators around but they all need the air flow and incoming and outgoing humidity and then give a total volume of condensed water but I need more than that. The size of the...
Thread 'Why work is PdV and not (P+dP)dV in an isothermal process?'
Let's say we have a cylinder of volume V1 with a frictionless movable piston and some gas trapped inside with pressure P1 and temperature T1. On top of the piston lay some small pebbles that add weight and essentially create the pressure P1. Also the system is inside a reservoir of water that keeps its temperature constant at T1. The system is in equilibrium at V1, P1, T1. Now let's say i put another very small pebble on top of the piston (0,00001kg) and after some seconds the system...
