jostpuur
- 2,112
- 19
Suppose a set X describes the possible states of some system, and suppose a function x\mapsto E(x) tells the energy level of each state. At temperature T the Boltzmann-measure, which will be the probability measure describing the state of the system, is obtained by formula
<br /> dp(x) = \frac{1}{Z(T)} e^{-\frac{E(x)}{k_{\textrm{B}}T}} d\mu(x)<br />
where Z(T) has been defined by
<br /> Z(T) = \int\limits_X e^{-\frac{E(x)}{k_{\textrm{B}}T}} d\mu(x)<br />
and where \mu IS SOME MYSTERIOUS BACKGROUND MEASURE, which seems to avoided in all physics literature.
For example, if we want to derive the Maxwell-Boltzmann distribution for particles in gas, we denote v=x (since the state of the particle is described by its velocity (or momentum) in this model), set E(v)=\frac{1}{2}m\|v\|^2 and \mu=m_3, where m_3 is the ordinary three dimensional Lebesgue-measure.
Another example: In Ising model we have X=\{-1,+1\}^L where L is a set whose elements describe lattice points. (Let's assume that L is finite.) Then we define \mu as the number measure so that \mu(\{x\})=1, and for non-trivial A\subset X \mu(A) tells the number of elements (states) in A. The energy function E is defined by using information about which points are neighbour points.
So the Boltzmann-measure consists of two parts. One part is the function e^{-E/(k_{\textrm{B}}T)}, and the second part is some background measure. The Boltzmann-measure is obtained, when the background measure is weighted with the function that depends on the energy and temperature.
Everytime I try to read about statistical physics, I only find discussion about the function e^{-E/(k_{\textrm{B}}T)}, but not about the background measure.
Suppose I define a measure \mu by a formula d\mu(x)=(e^{-\|x\|} + \sin(\|x\|))dm_3(x), and then claim that my Maxwell-Boltzmann measure is
<br /> dp(x)\sim e^{-\frac{m\|x\|^2}{2k_{\textrm{B}}T}} d\mu(x)<br />
Why is this wrong? I calculated "the function" correctly, and then weighted "some measure" with "the correct function".
How do we solve the correct background measure, which you will then weight with the function?
I have found this topic to be very difficult and frustrating. Everytime I have attempted to ask about the background measure, people change the topic to the function. Even professors. Like I explain carefully that I have understood where e^{-E/(k_{\textrm{B}}T)} comes from, but I have not understood where \mu comes from. Then people stare at me as if I was dumb and respond "the derivation of e^{-E/(k_{\textrm{B}}T)} was explained right there!". Apparently physicists don't like questions to which they don't know answers?
