The Carrier of an EMF: Resistance & Quantum Mechanics
In summary: CAR!The Electron is obviously subject to an insufficient potential difference to transfer itself and or its energy/force to an adjacent atom because of its own resistive properties dealing with the quantum mechanics of the electron structure as pertaining to orbitals and bond strength to its parent atom and that of neighboring atoms.
XPTPCREWX
101
The Carrier of an Emf is in many definite/indefinite parts the net of the circuits Total Resistance (Rt). These definite/Indefinite parts are the SMALLEST degree expressed to that of a single atom, the basic Resistive properties or qualities of Itself, and the electron structure as pertaining to orbitals and bonds of Copper Atoms, or (RESISTANCE) as we call it.
Therefore as a consequence... the longer the carrier of an EMF, the more definite/indefinite parts or Quantum Mechanics of “Atoms” the Emf must overcome and endure to pass current equally through the Circuit, Thus Increasing the Total Resistance in respect to the Emf.
The Carrier will be expressed as the Conductor Wire and the Conductor Load, because it carries the Emf.
For Example: r1+r2+r3+r4+r5+r6+r7+r8+r9...ect; Consider these Atoms throughout the Entire length of Conductor Wire to the SMALLEST degree. This is the basic Resistance of each atom to an Emf that must transfer electrons through it.
And R10+R11+R12+R13+R14+R15+R16+R17+R18...ect. Consider these also Atoms throughout the Entire length of the Conductor Load to the SMALLEST degree. This is the basic Resistance of each atom to an Emf that must transfer electrons through it.
Copper Atoms: Which is expressed above as Lowercase r's. (The Conductor Wire)
Aluminum Atoms: Which is expressed above as Uppercase R's. (The Conductor Load)
First Imagine a strand of Conductive Copper Wire consisting of Single Copper atoms, followed by a strand of Conductive Load. (r1+r2+r3+r4+r5+r6+r7+r8+r9+R10+R11+R12+R13+R14+R1 5+R16+R17+R18)
Now induce an Emf that is suposedly insufficient to work the Load.
Before I can move on I need to ask these questions…………….
1. A. What happens as a result of insufficient EMF?
B. Does the charge die along the way? If so WHY? HOW?
2. A. Does the insufficient Emf induce current on ANY electrons or only SOME?
B. If some do they squash against the ones that can’t move?
C. Is there momentarily Current only until the electrons come to a hault?
Are you asking about quantum resistance computation?
If so here is a start -> http://www.iop.org/EJ/abstract/0953-8984/1/29/009/
Actually I was asking about this...
Your question isn't very clear.
You at least need to define what you mean by "insufficient".
"die along the way" is equally obscure.
The charge does not change, only how it is distributed changes.
EMF is a potential for action.
Not an action unto itself.
You might think of a boulder sitting on a hill.
It has the potential to do work, but just may sit there doing nothing.
Does that help?
Does that help?
Lets Start with this…….Then we can move on,
1. What happens to an Electron which is slightly induced by influence of a weak Electro Magnetic Force in reference to an excessive resistance across a conductor?………A.) Does that ONE Electron or ANY electron for that matter squash against the ones that can’t move until they collide or repel to a hault? In a nutshell does it try to budge or squeeze against neighboring atoms as consequence of potential difference?....The Electron is obviously subject to an insufficient potential difference to transfer itself and or its energy/force to an adjacent atom because of its own resistive properties dealing with the quantum mechanics of the electron structure as pertaining to orbitals and bond strength to its parent atom and that of neighboring atoms.
To put this in stupid terms:
Think of it like your car just broke down...you are pissed off and you try to push your car...
you are planning on transfering all your Energy to that car...whether you might move it or not is due to its resistive properties and your applied force.
Now you might not be transfering ENOUGH energy to rotate your tires fully, BUT IT DOESNT MEAN THAT THEY DO NOT MOVE, AND IT DOESNT MEAN YOUR POWER ISNT DISSIPATING SOME AMOUNT OF ENERGY THROUGH OUT THE REST OF THE CAR, NOR DOES IT REFUTE ENERGY WORKING AGAINST THE RESISTANCE OF THAT CAR.
Looks like I guessed right the first time.
In bulk metals the electrons are not necessarily bound to orbitals.
To some degree the electrons are free to float around the material.
This is the mechanism that keeps the metal in one chunk instead of dissipating as a gas.
Resistance is a materials property and does not really apply to individual atoms.
For a better understanding of this, I would suggest you read the reference I pointed you to as well as others in the same line.
This still does not answer the question.
What part of your question did the referenced paper not answer?
You may also want to do some reading on Hall effect and super conduction.
FAQ: The Carrier of an EMF: Resistance & Quantum Mechanics
1. What is an EMF and how does it relate to resistance?
An EMF, or electromagnetic force, is a type of force that is created by the interaction of electric and magnetic fields. In terms of resistance, an EMF can cause electrical current to flow through a material, which creates resistance and can subsequently generate heat.
2. How does quantum mechanics play a role in the carrier of an EMF?
Quantum mechanics is a branch of physics that studies the behavior of matter and energy at a very small scale, such as at the level of atoms and subatomic particles. The carrier of an EMF, such as an electron, behaves according to the principles of quantum mechanics. This means that its behavior cannot be completely predicted, and there is a level of uncertainty in its position and momentum.
3. What types of materials have higher resistance to EMFs?
Materials that have high resistance to EMFs are known as insulators. These include materials such as rubber, glass, and plastic, which do not allow electricity to flow through them easily. This is because the electrons in these materials are tightly bound and do not have the freedom to move and create a current.
4. How can resistance to EMFs be reduced?
Resistance to EMFs can be reduced by using materials that are good conductors, such as metals. These materials allow electricity to flow through them easily, which reduces the amount of heat generated by the resistance. Additionally, using thicker wires and cables can also reduce resistance to EMFs.
5. Can exposure to EMFs be harmful to humans?
There is still ongoing research on the potential health effects of exposure to EMFs, but current scientific evidence suggests that low levels of EMF exposure from everyday devices, such as cell phones and power lines, do not pose a significant health risk. However, some individuals may be more sensitive to EMFs and may experience symptoms such as headaches, fatigue, or sleep disturbances. It is always a good idea to limit exposure to EMFs and follow safety guidelines when using electronic devices.
