The crystal structure for Ba2TiO explained with symmetries
Beyar
Member has been warned not to delete the template.
Hello!
I would love to get help on this particular question that I find extremely difficult to answer.
-"Bariumtitanate can under a certain set of conditions crystallize in the given structure. With the help of the compounds symmetries, explain how it is possible for it to achieve such a crystallization structure.
No equations are given for the specific problem so I am leaning towards that one has to use translation/reflection symmetries etc. to be able to solve this specific problem.
The given crystallized structure (transparent octahedron shape) can be seen in the picture.
  • Left: cubic unit cell model with green, red and small blue spheres at cube corners, face centres and body centre. Right: grey polyhedron with flat faces, a truncated octahedron-like shape.
It might help to label the species in the picture and then think about what happens if you try to move the center ion out of its place.
I believe that this species has undergone translation from either heat or cooling, which in turn has moved the Ti-ion (center ion) and caused the hexagon-shaped face to appear. Because from the start, the Ba2Tio species has a unit cell of a perovskite, which in turn is ideally face-centered cubic I believe. But I don't know how to translate this into "symmetry words", so to say..
What do you mean by translation? Do you mean the Ti4+ has moved to the center of an octahedron?
If you start with the cubic crystal structure in the picture you attached, what happens when you move the Ti4+ away from the center?
