The difference between sound and music
The discussion clarifies that the primary difference between sound and music lies in the structured frequency ratios of musical notes. Musical sounds are defined by specific relationships, such as A at 400 Hz corresponding to B at approximately 450 Hz and C at around 495 Hz. The concept of octaves is also highlighted, with A at 800 Hz representing a higher octave. The conversation emphasizes that this topic is more about musical theory than physics. Understanding these frequency relationships is essential for differentiating sound from music.
salam-it
What is the difference between sound and music?
What is the basic property of music?
musical sounds have certain frequency ratios with each other.
if A is 400 hz then B is nearly equal to 400*9/8 hz
and C is about 400*81/64 hz or 400*5/4 hz
and D is nearly 400*4/3 hz, etc.
one octave higher A is 800 hz.
google diatonic and tampered musical scales
This is not physics.
The rope is tied into the person (the load of 200 pounds) and the rope goes up from the person to a fixed pulley and back down to his hands. He hauls the rope to suspend himself in the air. What is the mechanical advantage of the system? The person will indeed only have to lift half of his body weight (roughly 100 pounds) because he now lessened the load by that same amount. This APPEARS to be a 2:1 because he can hold himself with half the force, but my question is: is that mechanical...
Some physics textbook writer told me that Newton's first law applies only on bodies that feel no interactions at all. He said that if a body is on rest or moves in constant velocity, there is no external force acting on it. But I have heard another form of the law that says the net force acting on a body must be zero. This means there is interactions involved after all. So which one is correct?
Let there be a person in a not yet optimally designed sled at h meters in height. Let this sled free fall but user can steer by tilting their body weight in the sled or by optimal sled shape design point it in some horizontal direction where it is wanted to go - in any horizontal direction but once picked fixed. How to calculate horizontal distance d achievable as function of height h. Thus what is f(h) = d. Put another way, imagine a helicopter rises to a height h, but then shuts off all...
