The Effect of Drag on a Pendulum: How Does Drag Affect the Motion of a Pendulum?
  • Thread starter Thread starter adenine135
    Drag Pendulum
Drag affects the motion of a pendulum by reducing the angle, height, and velocity compared to a scenario without drag. The resistive force of drag does work against the pendulum's motion, leading to decreased kinetic and potential energy. As a result, the pendulum swings with a smaller angle and reaches a lower height. The velocity of the pendulum is also diminished due to the opposing force of drag. Understanding these effects relies on the principles of conservation of energy, where the work done by drag reduces the overall energy of the system.
adenine135
The following link is a diagram of the motion of a pendulum I used in an experiment, where L represents the length of the pendulum arm:
http://farm3.static.flickr.com/2144/2052427314_f42f4cc193.jpg?v=0
Does drag cause the angle θ to be smaller or larger than it would be with no drag?
Does the drag cause the height h to be smaller or larger than it would be with no drag?
Does the drag cause the velocity of the pendulum to be smaller or larger than it would be with no drag?
Thanks! (We haven't covered drag in class yet, so any added insight would be appreciated)
Since it appears this is homework, could you first tell us what you know about the problem, what you think might be going on, etc., in an effort to sketch a possible solution? We won't just do it for you =)
Well honestly, we've been taught nothing about the effects of air resistance. Up until now, we were told to assume that air resistance is negligible. Our currently teacher has been out sick for almost 2 weeks and the substitute barely teaches.
The best I can do is guess the answer from common sense, but have no theoretical or quantitative proof to back up my answers:
  • the angle would be smaller due to drag
  • the height would be smaller due to drag
  • the velocity would be smaller due to drag
Your common sense seems to be working OK :smile:
One way to think about this is conservation of energy. You can get some useful information from that without knowing enough to solve equations for the "exact" motion of the pendulum.
You don't know enough physics yet to say what the magnitude of the drag force is, but you do know (from common sense) what its direction is.
Work = force x distance.
So as the pendulum moves, the drag force is doing work.
Think about how that work will change the kinetic and potential energy of the pendulum, and how those changes will affect its angle, height, and velocity.
Law of Conservation of Energy:
1/2 m(v_1)^2 + mgh_1 + W_other = 1/2 m(v_2)^2 + mgh_2
So W_other would be the work done by the drag force. But how can I get any supporting evidence for my answers from that?
This is what I've got so far in regards to the ballistic pendulum. I'm not sure if the last one is correct since the question specifically asks if the velocity will be larger or smaller. Also, if anyone can think of a better way to word anything or has any supporting evidence to add, I'd appreciate it.
  • the angle would be smaller - drag is a resistive force in the opposite direction
  • height would be smaller - the velocity is reduced by drag and, therefore, so is the distance the pendulum travels
  • the potential energy would be smaller - since height is smaller due to drag, so is potential energy (PE=mgh)
  • velocity of the pendulum and the embedded projectile immediately after impact would be smaller - Drag is parasitic force (subtracting from the force) . Velocity is directly proportional to the force equations. So as drag subtracts from the forward force, the velocity must decrease.
  • the initial velocity of the projectile would be smaller - Drag cannot effect initial velocity since it is at time equal to zero essentially. Drag has no time to be induced. Theoretically it would be equal.
Hello everyone, Consider the problem in which a car is told to travel at 30 km/h for L kilometers and then at 60 km/h for another L kilometers. Next, you are asked to determine the average speed. My question is: although we know that the average speed in this case is the harmonic mean of the two speeds, is it also possible to state that the average speed over this 2L-kilometer stretch can be obtained as a weighted average of the two speeds? Best regards, DaTario
The rope is tied into the person (the load of 200 pounds) and the rope goes up from the person to a fixed pulley and back down to his hands. He hauls the rope to suspend himself in the air. What is the mechanical advantage of the system? The person will indeed only have to lift half of his body weight (roughly 100 pounds) because he now lessened the load by that same amount. This APPEARS to be a 2:1 because he can hold himself with half the force, but my question is: is that mechanical...
Some physics textbook writer told me that Newton's first law applies only on bodies that feel no interactions at all. He said that if a body is on rest or moves in constant velocity, there is no external force acting on it. But I have heard another form of the law that says the net force acting on a body must be zero. This means there is interactions involved after all. So which one is correct?
