The Effect of Linear and Rotational Motion on Measured Weight
  • Context: High School
  • Thread starter Thread starter Pleiades7
The discussion revolves around the effects of linear and rotational motion on the measured weight of objects on a scale. It explores theoretical scenarios involving a car moving at high speeds and a person rotating while holding weights, examining how these motions might influence the normal force and the readings on the scale.
  • Some participants propose that classical mechanics dictates that motion does not affect weight, asserting that the normal force remains unchanged regardless of tangential motion.
  • Others argue that while the direction of acceleration changes, the vertical component affecting the scale's reading remains constant, thus not altering the measured weight.
  • A participant suggests that a car moving in a straight line could exhibit a slight decrease in measured weight at high speeds, particularly approaching orbital velocity, although this effect is considered negligible for typical highway speeds.
  • Another viewpoint posits that the centrifugal force experienced by weights during rapid rotation does not change the absolute value of the weight force, despite changes in relative force directions.
  • Some participants discuss the implications of circular motion, suggesting that as the diameter of the circle increases, the centrifugal force could have a component that reduces the measured weight on a scale.
  • There is a mention of the Coriolis force and its potential impact on weight measurements for objects in motion, particularly in naval contexts.
  • A participant questions whether the discussion pertains to measurements of force or mass, indicating a potential ambiguity in the terms used.
Participants express multiple competing views regarding the effects of motion on measured weight, with no consensus reached on the implications of linear and rotational motion in the scenarios presented.
Some arguments depend on specific assumptions about the nature of motion and the definitions of weight and force, which remain unresolved in the discussion.
Pleiades7
Consider an extremely long and perfectly calibrated scale. A car with a mass of 1000 kg is placed on it, and the scale registers this weight accurately. Now, suppose the car begins to move, reaching very high speeds. Neglecting air resistance and rolling friction, if the car attains, for example, a velocity of 500 km/h, will the scale still indicate a weight corresponding to 1000 kg, or will the measured value decrease as a result of the motion?
In a second scenario, imagine a person with a body mass of 70 kg standing on a scale while holding two 5 kg weights, one in each hand. The total reading on the scale is therefore 80 kg. If the person then begins to rotate rapidly around their own vertical axis, the arms will extend outward as the weights experience an increasing centrifugal effect. In this state, the acceleration of the weights becomes largely horizontal rather than vertical. Would this redistribution of forces alter the total normal force on the scale, and consequently, the measured weight?
This setup can also be modeled mechanically: two equal masses are attached to opposite ends of a rotating rotor, which is placed on a scale and spun at high angular velocity.
The central question, therefore, is whether any object rotating rapidly about its own axis in a plane parallel to the ground exhibits a measurable reduction in its apparent weight due to the redistribution of centripetal and normal forces.
Motion has no impact on weight, classically.
The only sorta exception is a vertical oscillation/unbalanced rotation would cause the reading to oscillate.
Why would it? Tangential motion doesn't affect the normal force.
The direction of the acceleration vector does, yes. But the magnitude of that vector also increases, in such a way that the vertical component, which is what affects the reading on the scale, remains the same.
No. Again, why would it? That would amount to the person being able to lift themselves by spinning around with weights.
Actually, if the car is moving in a straight line (or, to be precise, has its steering straight at all times) on Earth I think its measured weight will decrease slightly - in fact, it will reduce to zero when the car's velocity is equal to orbital velocity at ground level (which I make to be about 60 times the suggested 500km/h, so this is very much a negligible effect for highway speeds). This isn't anything to do with rotational motion, and in fact I would not expect the effect if the car were driving in a circle (any circle smaller than a great circle anyway).
The spinning weights one likewise has no effect.
It seems I know the origin of the question:
  • Haha
Newton's laws of motion involve force, mass and acceleration. They do not involve the velocity of an object. Note that velocity is relative (to a frame of reference). The force on a car is the same whether you consider the car to be at rest or moving. The force depends on the acceleration of the car and not its velocity.
Because there is the vertical constant acceleration of gravity, the direction of the total acceleration of the weights, regardless its magnitude, can never reach a horizontal direction.
Pleiades7 said:
Would this redistribution of forces ...
You are confusing relative comparisons and absolute force values. Just because the relative comparison of vertical and horizontal the forces changes, doesn't mean that the absolute value of the weight force changes.
That was my thought too.
Classically, no. The total mass is unchanged, as is the acceleration of the center of mass. So the net force is also unchanged.
On the contrary, I would expect an effect for all circle sizes. The effect would gradually increase as the diameter of the circle increases toward a great circle. [Depending on exactly what one holds constant as the circle diameter is increased]
Let us think in terms of the fictitious centrifugal force and arrange for the centrifugal force to remain constant in magnitude as the circle's diameter is increased. For a small circle, the centrifugal force is directed almost tangential to the Earth's surface. For a larger circle the centrifugal force has an component that is normal to the surface. That component acts to reduce the measured weight of the vehicle. The vehicle would ride a bit higher on its springs.
For spinning weights (think two weights on the end of a string) the weight force of two weights would not be parallel. They would have an angle between them. Their vector sum would be lower than the sum of their magnitudes.
Note that the effect of weight reduction for a car driving at high speeds depends on the direction of travel. It can be seen as a manifestation of the Coriolis force in the vertical plane. One sees the relevant correction in range tables for naval gunfire. See pages 449 and 450 here.
Are you referring to a measurement of force or mass?
  • · Replies 29 ·
  • · Replies 21 ·
  • · Replies 47 ·
  • · Replies 60 ·
