How can you factor out x from the original term?
In summary, the expressions $\sqrt{2x^2 + 1}$ and $x \sqrt{2 + \frac{1}{x}}$ are not equal, but they can be shown to be equal for $x > 0$ by factoring out $x$ and using the identity $\sqrt{x^2} = x$. For $x \neq 0$, the expression is equal to $|x|\sqrt{2 + \frac{1}{x^2}}$.
tmt1
234
In a text,
We have this:
$\sqrt{2x^2 + 1}$
is equal to
I am confused as to how to factor out x from the original term.
Mathematics news on Phys.org
The two expressions are not equal. Actually,
\(\displaystyle \sqrt{2x^2 + 1} = x\sqrt{2 + \frac{1}{x^2}}\quad \text{for}\quad x > 0.\)
For if $x > 0$,
\(\displaystyle 2x^2 + 1 = 2x^2 + \frac{x^2}{x^2} = x^2\Bigl(2 + \frac{1}{x^2}\Bigr),\)
so that
\(\displaystyle \sqrt{2x^2 + 1} = \sqrt{x^2\Bigl(2 + \frac{1}{x^2}\Bigr)} = \sqrt{x^2} \sqrt{2 + \frac{1}{x^2}} = x\sqrt{2 + \frac{1}{x^2}}.\)
Note the use of the identity $\sqrt{x^2} = x$, $x > 0$.
More generally,
\(\displaystyle \sqrt{2x^2 + 1} = |x|\sqrt{2 + \frac{1}{x^2}}\quad \text{for} \quad x \neq 0\)
FAQ: How can you factor out x from the original term?
1. What is the factor of a square root?
The factor of a square root is the number that, when multiplied by itself, results in the given square root. For example, the factor of √9 is 3, because 3 x 3 = 9.
2. How do you find the factor of a square root?
To find the factor of a square root, you can use a process called "prime factorization". This involves breaking down the number under the square root into its prime factors, and then pairing them up in groups of two. The factors that remain in pairs are the factors of the square root.
3. Can the factor of a square root be a decimal?
No, the factor of a square root must always be a whole number. If the square root results in a decimal, it is called an "irrational number" and cannot be written as a factor.
4. What is the difference between the factor of a square root and the square root of a number?
The factor of a square root is a number that can be multiplied by itself to result in the given square root. The square root of a number is the number that, when multiplied by itself, results in the given number. In other words, the factor of a square root is the opposite of the square root function.
5. Can the factor of a square root be negative?
Yes, the factor of a square root can be negative. This is because when you multiply a negative number by itself, the result is a positive number. For example, the factor of √25 can be both 5 and -5, because 5 x 5 = 25 and -5 x -5 = 25.
