The motion of the mass starting from its highest point t=1.3
The discussion focuses on a physics problem involving a spring-mass system oscillating vertically. The user has successfully calculated the spring constant (705.6 N/m) and amplitude (0.24 m) but struggles with finding the distance traveled by the mass after 1.3 seconds using the formula x = A cos(wt). Other participants suggest checking calculations at t=0 and t=1.5 seconds for insights and remind the user to ensure their calculator is set to radians. The expected answer for the distance traveled is 0.88 meters.
Marisabel
(a) A large spring has one end attached to the floor and a platform attached to its upper end. On the platform is placed a mass of 30 kg. The mass of the platform itself is 10kg. The spring-platform-mass system is then set into vertical oscillations with a period of 1.5 s. Determine
(i) the stiffness (spring constant) of the spring
(ii) the amplitude of the motion if the maximum speed of the mass is 1 ms-1.
(b) (i) If the motion of the mass (in part (a)) is timed starting from its highest point, calculate how far it has traveled in 1.3 s
x= A cos (wt)
The answer must be x= 0.88m
I've solved part a) already
k= 705.6 N/m
w= 4.2 rad/s
A= 0.24 m
but I'm struggling in part b)
Can someone help me using the formula
x= A cos (wt)PS: This is a past exam paper, I'm using it to study and practice for my exam.
x= A cos (wt)
k= 705.6 N/m
w= 4.2 rad/s
A= 0.24 m
Did you think about plugging ##t = 1.3s## into that equation?
yes. I get a different answer.
Try plugging in ##t = 0s## and ##t=1.5s## and see if that gives you any ideas.
What is x at t=0? And what is x at t=1.3 s? What is the displacement during that time?
By the way, have you set the calculator to radians?
