The Paradox of Infinity
  • Thread starter RuroumiKenshin
  • #126
drag
Greetings !
Originally posted by Mentat
That's not all I'm doing. I'm also reasoning with
you on the nature of infinity. You continue to
side-step my arguments, and it's rather frustrating
to have to keep repeating them.
The only reasoning that makes sense is the
"likely one apparently supported by observation" =
science. Since I made a hypothetical assumption
for the sake of this discussion your attempts
to disprove it are ridiculous because you're basicly
saying that there's some absolute Universal reason
which denies my hypothetical assumption and there
does not appear to be any basis to support such a claim.
It's not. I do feel I have an obligation to defend my
position, but if you would prove me wrong (which you
don't seem to want to do, given your obvious side-stepping tendencies), I would give up that position.
Prove you wrong ?
You can understand from the above that there's
no need for me to do that. But, if you wish:
My reasonig system is that entities that are finite
CAN become infinite and the other way around.
This is done in a procedure I'll call - "metafinity".
That is dead wrong. Science makes plenty of assumptions.
That is dead wrong. :wink:
For example: it assumes that there is an objective Universe, even thought this cannot be proven or falsified. This is just one example, but it should serve to prove that Science makes assumptions.
Show me a real science book that says that.
Science doesn't even adress such issues, it just
deals with observation and connected reasoning.
You've been talking to Alexander too much...:wink:
He, indeed, believes in science. But, he simply
misinterprets it.
Yes it does. If something was smaller, and then was bigger,
it got from smaller to bigger. If it did so, then it
expanded, because "expansion" means "getting bigger".
Nope, it "metafinited". :wink:
I like to believe that all of my points have been relevant, but, even if they haven't been, they have all had merit (as have all of yours), and should thus be considered directly, instead of being side-stepped.
They have merit as long as you truly mean what you
say and not just talk because you feel you have to.
Live long and prosper.
  • #127
RuroumiKenshin
Give an example, please.
  • #128
3,762
I did, in my response to drag.
  • #129
3,762
science.
This is an assumption with no basis, but I'll ignore it, for the time being.
Yes there is basis, the nature of the term "infinity". It would take an infinite amount of time to reach infinite size, if you started out finite. This is just a result of using the term "infinite".
Prove you wrong ?
This is not a "reasoning system", it is an assumptions, without basis. You are speculating, instead of deferring to the already rigorously defined avenues that Science has been pursuing. IOW, you are presenting a speculation, without Scientific basis, and expecting it to solve a problem that scientists have been struggling with (in a scientific manner) for a very long time.
Exactly, it deals with observations, as though they actually existed outside of the mind of the "beholder". Remember, just because it seems like an obvious conclusion, doesn't mean that it isn't an assumption (which cannot be proven or falsified, btw).
Again, you attempt to solve a scientific problem through an unscientific approach (presenting your own speculation, and (in case you hadn't noticed) redefining the properties of "infinity").
  • #130
479
Yes it does. If something was smaller, and then was bigger, it got from smaller to bigger. If it did so, then it expanded, because "expansion" means "getting bigger".
Expansion isn't necessarily getting bigger. Take a sugar cube, one piece. Crush it - many pieces. Expansion. Number of distinguishable pieces expands. Think entropy, varing timeflow, evaporation into vacuum, you can get to possible illusion of spatial expansion.
  • #131
3,762
That's not expansion, that's decomposition.
Number of distinguishable pieces increases.
  • #132
479
semantics again. You don't even try to understand if you sense any loose semantics.
Number of distinguishable spacetime positions, measured in planck units, increases. If your only measure of distance is number of planck lengths, you perceive it as expansion.
I'm not to pursue this idea. Discard it when you understand it.
  • #133
110
this thread is getting bizarre.
even agreeing to the fact that such a phase transition from finite to infinity may be logically consistent it certainly did not happen AFTER THE BIG BANG since physics does not allow such a phenomenon.
so the point is if the universe is infinite today it had to be infinite at the time of the big bang due to the constraints of physics.metafinity did not happen after the big bang and we are not concerned with what happened before.
AN APPLE FALLS ON EARTH.WHY?BECAUSE PHYSICS SAYS THERE EXISTS A FORCE CALLED GRAVITY THAT ACTS ON IT.WHAT IS A FORCE? WHAT CAUSES IT?WELL.....SO YOU SAID PHYSICS DOES NOT MAKE ANY ASSUMPTIONS.WHAT ABOUT THE ASSUMPTION THAT THE UNIVERSE IS "REAL" OR SAY LOGICAL,THAT WE OBSERVE THINGS THAT ACTUALLY EXISTS OUT THERE.THINK ABOUT IT.
  • #134
3,762
Yes, the particles "expand" away from each other, is that what you mean?
If so, then your reasoning only works when "expansion" means "getting farther apart". However, the Big Bang theory (when coupled with General Relativity) dictates that the spacial dimensions themselves, are "getting bigger" (expanding).
  • #135
3,762
Sage, you've done it again! Very eloquently put.
  • #136
479
Yes. Number of distinguishable spacetime positions IS 'spacial dimensions themselves'. Particles come only after that. If given particle 'fills' fixed number of spatial positions, it will not 'expand' with space. Purely my opinion. Entropy increases with number of possible states, so I speculate it has to do with it even though particles remain intact.
  • #137
drag
Greetings !
I appologize for my late response. I've
been abroad for a few days and now I'm back. :smile:
That is indeed an assumption with no basis. :wink:
That's why it makes sense - because "bases",
ANY bases, make no sense. In this case, however,
I did not and will not provide a basis by not
defining the word sense. Observation is just
something - whatever, the rest is assumptions
and likely patterns.
Since niether the finite nor the infinite presents
even partial solutions to the mystery of their existence
I see no reason to consider any solution as absolute,
beyond the likely preferences infered from observation.
If you wish to deal with absolute reasoning
please refer to the God & Religion forum. :wink:
I'm not trying to solve anything and nor am I
presenting any scientific basis. I'm just making
a hypothetical assumption because this thread
has made it enitially already and then went on
to discuss the possibilities of expansion in
such a case. BTW, this IS a reasoning system just
like any other. It just doesn't appear to apply to
observation, for now.
No, it just deals with observation. :wink:
They don't mention this part in physics
books because they wan'na save the forests.
We just have observed data, "outside" makes no
scientific sense in addition to what's observed.
And what was that scientific problem, Mentat ?
Sage, our current cosmology models are patheticly
primitive in terms of really providing some answers.
It indeed seems likely according to modern physics
that the Universe could not just become infinite
but science can only state likeliness, it can't
prove things beyond any doubt.
Also again, read my lips - SCIENCE MAKES NO ASSIMPTIONS.
I don't know of what's an "outside reality". Physics
deals with measurements of space and time but it
does not have a parameter called "outside reality"
nor does it have a numeric value for such a parameter. :wink:
Clear ?
Doubt or shout !
  • #138
drag
Hey Majin ! Why did you change your username ?
  • #139
"....However, I'm talking about space itself. If you take a space that is infinite (as in, having no end), how could you possibly add more space to this?... "
This may have already been mentioned in this thread -- but an answer to the above would be:
To 'add' more space to space, you get rid of all of the junk that is taking up space within the infinite.
Say like, the Earth, dissolves and the area where solid mass exists -- becomes added space.
  • #140
It comes from a childs joke; "How many sides to a Circle?"
The answer is "Two, inside and outside."
From that we define 'space', and that is by delineation.
The definition of "infinite" is 'undelineated space', or "Space with no boundries", but this brings us to a simply problem.
All of the thoughts in our heads are 'delineations of space', hence we can conclude that an 'undelineated space', a 'space without boundaries', is something that we cannot conceive of.
Ergo, no thoughts on the subject, no math, no concepts that will "fill the intellectual bill" as there cannot be, because every thought, is a "delineation" of space.
Thanks..............have nice thoughts!
  • #141
1,648
What if the planck lenght is expanding with the space itself.. having space always measure the same in units of planck length.....
  • #142
3,762
How is it that you make an assumption about the basis of my assumption, while at the same time denouncing that such a basis can ever exist?
There is one thing that is absolute about finity and infinity: their definitions. They are rather clearly defined (as far as words go) and should thus only be refered to in a way that honors their meaning (otherwise, you could just as easily be discussing some entirely unrelated term).
such a case.
Actually, your idea is not an hypothecical assumption, as hypotheses can be tested.
Then it is not science, and should restrict itself from scientific forums.
I don't understand this, what do you mean?
I thought it was the expansion of the Universe (or, at least, whether the Universe can be finite and yet expanding).
If Science makes not assumptions, then it should be perfectly comfortable with someone's saying that there is nothing but a singular Mind, and that we just percieve there being an objective reality. As it is, Science is not comfortable with this assumption, and must thus be making an assumption to the contrary.
"Outside reality" refers to that which does not exist abstracly, in one's mind, but rather has physical/tangible existence.
  • #143
drag
Greetings !
I'm loosing the thread of thought here.
In general, observation as I meant it is not something
that has a strict definition. It's just everything = existence.
O.K. But, the strict defintion is in no way a
justification of your absolute reasoning, so I do
not see how that helps you to prove your baseless
assumption about the inability of the finite to
become infinite or the other way around.
O.K. Mind proving the inability of proof for my
hypothetical assumption ?
(You see the difference in our approaches to
assumptions ? You make absolute assumptions and
are naturally asked to prove their absoluteness.
btw, in most cases you still keep arguing to
no awail - don't know why , are you regarding
our discussions as "win or loose" ? Not a very smart
attitude if you ask me. :wink:
Anyway, I just make probabalistic assumptions and
again if you disagree with them the burden of
proof of their impossibility is upon you.
Now, this is NOT a way to "win" arguments. I really
don't care if I end up looking like a complete
idiot , sometimes...:wink:
This is just the way that appears to be the most
basic in argument construction or indeed in
reasoning - the Antrophic principle. Again, even
that may be shown probabalisticly wrong in the future,
but today and throughout human history it's been
pretty reliable...:wink:)
scientific forums.
Rediculous !
The only and main way that science can expand in addition
to new types of observation is new reasoning systems
applied to it, that is the source of all current
scientific theories - to find the most consistent
perspective.
What's "outside" ?
You think your PC screen is "outside" of "you" ?
Scientificly that term makes no sense. Physics
uses the concept of distance that is a parmeter
applied to a certain type of observation data.
But, except saying that that piece of observation
data is inconsistent according to our applied reasoning,
which is clearly not the case, there is apparently
nothing more that one can accuse science of here.
and yet expanding).
And I thought that this thread refered to an
infinite Universe in the first place. So my assumption
may be considered unscientific, but then wouldn't
the whole thread be like that (in terms of the
Q&As) in the first place ? :wink:
WHO SAID IT'S NOT COMFORTABLE WITH THAT ASSUMPTION ?
Science makes no true/false judgement on this
point at all because there is no acceptable
reasoning for now that makes us view at least
some observation data as relevant to this point at all.
If you remember what I said to LG FGNF(may he find a
good new forum ) many times it was that there
appears to be, for now at least, no evidence to
either support or not support his hypothesys which
is why it's simply an unneccessary assumption.
Do not confuse this with the reason he was banned. :wink:
The reason he was banned was connected to the fact
that he did try to present such "evidence" by
twisting science (sometimes in intresting, but most
times in rather clumsy ways resulting from his
relative poor knowledge of it) and by not really listening
to people trying to correct him, thus creating some
misleading threads with misleading subjects which
had the potential of misguiding the perspectives
of other members. (Still, though neccessary, it's ashame he was banned...:frown:)
Can you make the separation ?
Does Science (and in the remote case that after reading
this message you'll still say "yes", please do provide
an explanation :wink:) ?
Peace and long life.
  • #144
3,762
What are you talking about? Infinity's strict definition is that it goes on forever. Part of finity's strict definition is that it does not go one forever. Thus, they are incompatible. One cannot ever become the other. They are of a qualitatively different order.
I already told you, it defies the definitions of the words that it makes use of (finity and infinity).
No, I don't think that I can win or lose this argument, but I do think that your reasoning (on some of these points) is flawed, and so I respond.
Thus, yours is not a scientific method, as probablistic assumptions, that may or may not even be provable, are not in the realm of science.
Rediculous !
perspective.
This is untrue. The Scientific method is one reasoning system, an cannot have other reasoning systems applied to it.
What's "outside" ?
applied to a certain type of observation data,
but except saying that that piece of observation
which is clearly not the case, there is no more
meaning that "outside" recieves in science.
While Physics has shown that there is no relevance to saying that one thing is "outside" of another, the other Sciences make full use of this concept.
No, there is nothing wrong with an infinite Universe. The problem arrises in trying to say that it wasn't infinite, but became infinite.
Science makes a distinction between the mind of a human observer and that which is observed (othewise the Scientific method would become completely invalid).
  • #145
drag
Greetings !
What are you talking about? Infinity's strict definition is that it goes on forever. Part of finity's strict definition is that it does not go on forever.
Indeed.
Prove it, please. :wink:
I do not see any connection whatsoever between the
definitions of the words and the impossibility of the
proccess of "metafinity" which I hypothesized above.
In that case I must say that you have no idea what
science is all about.
The same as the previous response.
The same as the pre-previous response. (Unless of
course you can provide an example ? Don't think so...:wink:)
Again, why ? Explain, please.
There is indeed a problem from the perspective of modern
science. But that's just a probable problem, just like
all of science.
First of all, in general the concept of an independent
observer has been abandoned by science almost a century
ago, better get uptodate. :wink:
Second, there is no scientific distinction between
the "mind of a human observer" and any other group
of molecules (except their types and formations) and
so it will remain until shown to likely be otherwise
through some scientificly relevant evidence.
Doubt or shout !
  • #146
3,762
I already did. Infinity goes on forever. Finity does not. Now, without defying these definitions, show me how finity can turn to infinity.
Then look again.
No, I think it is you who doesn't understand the Scientific Method. It starts with observation, then the one collects data, then one hypothesises, then one rigorously tests the hypothesis, and then (if the hypothesis happened to survive testing) one has formulated a theory. Science is based on theories and observations, not on wild assumptions of "what if".
How so? The Scientific Method (as I have shown above) is one reasoning system. If you add other reasoning systems, then you have left the realm of the Scientific method.
Alright, an example: Neurology. Neurology give a distinction between that which the mind observes, and that which is observed.
all of science.
No, it's not just a scientific problem, it is a problem of definition. (See above).
It was abandoned by subatomic physics, nothing more. I have some knowledge of subatomic physics (whether you wish to acknowledge that or not), but I also have knowledge of other branches of science, and they still make the distinction on an everyday basis.
  • #147
740
Infinity itsself is a paradoxical notion that we give to concepts that we cannot yet fathom due to limitations on science, or the limits of our minds. Infinity cannot be proven, as there is no solution to the problem. Therefore since infinity represents a problem with no concievable solution, it can never be definitively solved. Take PI for example. As of yet no known solution (last I heard was to the 10 billionth decimal place). So we assume it's infinite because the solution is perhaps beyond our minds to comprehend. But we'll keep trying, and we may keep calculating and never reach the end, so the infity of the problem will remain an unsolved issue.
Such is the nature of the universe. We say that it's infinite, but it is only a theory. Can we prove the universe is infinite? No. If it is indeed infinite, then we will never reach the end, and thus the theory remains so, whereas with finite measurement, we may be able to one day in a distance unconcieved future reach the end of a finite universe. Perhaps one day we will one day develop the capacity to travel billions of light years to the other side of the "known" universe, only to discover that we've barely moved in the scope of things. Perhaps the universe is finite, and 1 trillion light years distance is merely .0000000000001 percent of the distance to the edge. It could be that the universe is finite, but as yet it's impossible for us to comprehend the size of it. It's all about perception, and I know we are still but mere children in our understanding of the universe.
  • #148
drag
Greetings !
Zantra, I'd just like to correct you by mentioning
the fact that math is an absolute abstract (thought out/
invented) system and that [pi] IS proven to be irrational
by an appropriate mathematical theorem. Thus, it will
never end.
It's a hypothetical proccess I proposed, remember ? :wink:
If I knew how it is done it would be more than
just hypothetical. Now, don't try to play reverse
psychology on me cause if you say something's
impossible you're the one who has to prove it.
The scientific method is not a reasoning system.
The scientific method uses reasoning systems.
All scientific theories are formulated by applying
reasoning of some sort to observed data.
For example, If I reason that everything has a source
then I can say that this orange is the product of
some other physicly defined entity. If I reason
that everything appears out of thin air then
I can say that this orange just materialized.
Of course, observation and the reasoning applied
to it and accepted as scientific are mutualy
connected. We draw our reasoning principles from
observation and we apply them to observation.
Another example - I consider everything that is
mathematicly consistent and appears to discribe
observation to be science. This approach is based
upon the reasoning that math applies to observation.
This in turn has it's source in the fact that it
appears to us that most observation data includes
some basic common principles that we summed up in
the form of mathematics.
I don't think I understand the relevance here.
The distinction you're making is a distinction within
observation. But, for something to really be "outside"
one needs to prove that something exists that is
independent of observation (which I personally think
is probably impossible because I think that existence
and observation are most likely inseprable synonyms in
this respect).
That's because they do not really know how to do without it,
for now at least. The most fundumental principles
of our reasoning are separate entities, empty space
and more. Further more, the issue becomes much
less of a problem at macroscopic scales. So, approximations
do fine for the most part aspecially considering that
all macroscopic scale sciences are still full of these.
  • #149
740
Greetings !
never end.
Ok you say it's been mathmatically proven that there is no end to PI. Show me. YOu can't. We make the "assumption" that it's a neverending loop because we cannot calculate an absolute value. It's again, a "theory"
PI is a bad example, so let's try a different angle. We used to believe the world was flat and that eventually if you reached the end you'd just fall off. We didn't "KNOW" it was, but society made this assumption based on thier limited knowledge of the world around them. Then columbus proved them wrong. It's the same scenario. Making assumptions based on limited date to hypothesize, but again we come to the word "theory" which is not proven. To put it in the most basic terms. The earth is round. I can travel along an axis and eventually I come back to the same point, thus the observation is proven correct. Prove to me with unrefuteable data or conclusive proof that the universe is infinite. And that, is simply my point.
Infinity is a self-defeating paradox that cannot be proven because the very nature of the concept represents a lack of proof or definition.
  • #150
drag
Greetings Zantra !
Purhaps you misunderstood me. I agree with you
in general about REAL infinity. However, when
it comes to math which is a strict and defined
system that we invented - it is capable of proving
something within it is infinite.
Here's the theorem and related links if you wan'em:
http://www.shu.edu/projects/reals/infinity/irrat_nm.html [Broken]
http://mathworld.wolfram.com/IrrationalNumber.html
http://mathworld.wolfram.com/Pi.html
Related Threads on The Paradox of Infinity
  • Last Post
  • Last Post
  • Last Post
  • Last Post
  • Last Post
  • Last Post
  • Last Post
