The Pauli-Lubanski vector and angular momentum
  • Context: Undergrad
  • Thread starter Thread starter redtree
    Poincare algebra
19 replies · 5K views
redtree
TL;DR
I have seen it stated but not proven that in the formula for the Pauli-Lubanski vector, the orbital angular momentum drops out from ##M_{\rho \sigma}## because of the anti-symmetry with the momentum operator, such that it includes only the spin part of the angular momentum. Where can I find an explicit proof of this statement?
Given $$M_{\rho \sigma} = i (x^{\rho} \partial_{\sigma} - x^{\sigma} \partial_{\rho})$$
and $$W^{\mu} = \frac{1}{2} \epsilon^{\mu \nu \rho \sigma} P_{\nu} M_{\rho \sigma}$$
Why does ##W^{\mu}## pick up only the spin part of the total angular momentum?
Looks to me like you can just plug in ##M_{\rho \sigma}## and the derivative for ##P_{\nu}## and just compute that ##W_\mu## is zero, as you have defined it (without the spin component). You will just need to appeal to the anti-symmetry of the Levi-Cevita symbol. I see a couple terms with a repeated index in the Levi-Cevita symbol and couple where it gets contracted with symmetric terms. It is about 3 lines of index algebra/calculus.
redtree said:
I apologize, but I don't see it.
You only see it if you perform the calculation explicitly. You probably need to use that partial derivatives commute. Also, don't forget to add a test function on which the operators act for clarity.
If you have problems, you need to be more explicit than "I don't see it". Stating your problem very specifically enforces you to think more clearly, bringing you to a solution more closely.
Last note: "I've seen it stated" requires an explicit source here on PF. We need context to help.
Just to get things started:
##W^{\mu} = \frac{1}{2} \epsilon^{\mu \nu \rho \sigma} P_{\nu} M_{\rho \sigma}=\frac{i}{2} \epsilon^{\mu \nu \rho \sigma} \partial_{\nu} (x_{\rho} \partial_{\sigma} - x_{\sigma} \partial_{\rho})##
or with test function:
##W^{\mu}f = \frac{1}{2} \epsilon^{\mu \nu \rho \sigma} P_{\nu} M_{\rho \sigma}f=\frac{i}{2} \epsilon^{\mu \nu \rho \sigma} \partial_{\nu} \left( (x_{\rho}\partial_{\sigma} - x_{\sigma} \partial_{\rho})f\right)##
Now work it out. The derivative on the coordinates gives a (symmetric!) metric, and partial derivatives commute. Conclusion?
Is this correct? I apologize if the Latex syntax is wrong for Physics Forums. If it is, maybe you can cut and paste into another Latex editor....? (or you can tell me what I did wrong and I can repost)
$$\begin{equation}
\begin{split}
W^{\mu} &= \frac{1}{2} \epsilon^{\mu \nu \rho \sigma} P_{\nu} M_{\rho \sigma}=\frac{i}{2} \epsilon^{\mu \nu \rho \sigma} \partial_{\nu} (x_{\rho} \partial_{\sigma} - x_{\sigma} \partial_{\rho})
\end{split}
\end{equation}$$
where
$$\begin{equation}
\begin{split}
\epsilon^{\mu \nu \rho \sigma} \partial_{\nu} (\epsilon^{\mu \nu \rho \sigma} x_{\rho} \partial_{\sigma} - x_{\sigma} \partial_{\rho}) &= \epsilon^{\mu \nu}\partial_{\nu} (\epsilon^{\rho \sigma}x_{\rho} \partial_{\sigma} - \epsilon^{\sigma \rho} x_{\sigma} \partial_{\rho})
&= \epsilon^{\mu \nu}\partial_{\nu} (\epsilon^{\rho \sigma}x_{\rho} \partial_{\sigma} + \epsilon^{\rho \sigma} x_{\rho} \partial_{\sigma})
&= 2 \epsilon^{\mu \nu \rho \sigma} \partial_{\nu} x_{\rho} \partial_{\sigma}
&= -2 \epsilon^{\mu \rho \nu \sigma} x_{\rho} \partial_{\nu} \partial_{\sigma}
\end{split}
\end{equation}$$
such that
$$\begin{equation}
\begin{split}
W^{\mu} &=-i \epsilon^{\mu \rho \nu \sigma} x_{\rho} \partial_{\nu} \partial_{\sigma}
\end{split}
\end{equation}$$
$$\begin{equation}
\begin{split}
\end{split}
\end{equation}$$
where
$$\begin{equation}
\begin{split}
\end{split}
\end{equation}$$
such that
$$\begin{equation}
\begin{split}
\end{split}
\end{equation}$$
I'm not sure why you split up the epsilon symbol, but I think you're looking in the right direction. Take a look at the expression
##\epsilon^{\mu \nu \rho \sigma} \partial_{\nu} (x_{\rho} \partial_{\sigma}f - x_{\sigma} \partial_{\rho}f)##
with ##f## a test function. If the derivative ##\partial_{\nu}## hits e.g. ##x_{\rho}## you get ##\eta_{\nu\rho}## which is symmetric; if it hits ##\partial_{\sigma}## you get ##\partial_{\nu}\partial_{\sigma}## which is symmetric. Same for the other two terms. Contracting these symmetric terms with the epsilon symbol gives you zero. So you get
##\epsilon^{\mu \nu \rho \sigma}(\eta_{\nu\rho} \partial_{\sigma}f + x_{\rho}\partial_{\nu}\partial_{\sigma}f) - [\sigma \leftrightarrow \rho] = 0 + 0 - (0+0) = 0##
It could be even done quicker if you realise that the epsilon symbol is antisymmetric in ##\sigma## and ##\rho##, so it becomes
##2\epsilon^{\mu \nu \rho \sigma}(\eta_{\nu\rho} \partial_{\sigma}f + x_{\rho}\partial_{\nu}\partial_{\sigma}f)##
If you don't understand why the contraction of an antisymmetric and symmetric tensor gives zero, you should work that out first.
Reply
I understand why symmetric and anti-symmetric tensors contract to zero.
I apologize, but then I don't see how spin come out as non-zero.
Ok, let's define the total angular momentum
##J_{\rho\sigma} = M_{\rho\sigma} + S_{\rho\sigma}##
with ##S_{\rho\sigma}## the spin-operator. Now calculate
##\epsilon^{\mu\nu\rho\sigma}P_{\nu}J_{\rho\sigma}##
Clearly
$$\begin{equation}
\begin{split}
\epsilon^{\mu\nu\rho\sigma} P_{\nu} J_{\rho\sigma} &= \epsilon^{\mu\nu\rho\sigma} P_{\nu} (M_{\rho \sigma} + S_{\rho \sigma})\\
&= \epsilon^{\mu\nu\rho\sigma} P_{\nu} M_{\rho \sigma} + \epsilon^{\mu\nu\rho\sigma} P_{\nu} S_{\rho \sigma}\\
\end{split}
\end{equation}$$
but don't orbital and spin angular momentum have the similar commutation relations? So why the difference?
Sorry if I'm being daft.
With themselves and with the total angular momentum ##J##, yes. With the linear momentum ##P##, no.
Because spin and angular momentum operators act on two completely different subspaces of the space of states. Angular momentum and linear momentum act on the same subspace, i.e., the ##L^2(\mathbb{R}^3)## part.
Reply
redtree said:
##\textbf{W} = \star (\textbf{M} \wedge \textbf{P})##, where ##\textbf{M} = \textbf{X} \wedge \textbf{P}##, such that ##\textbf{W} = \star (\textbf{X} \wedge \textbf{P} \wedge \textbf{P})##. However, isn't ##\textbf{P} \wedge \textbf{P} = 0##, such that ##\textbf{W} =0##?
Yes, you are correct and there is an error in the Wikipedia reference. The proper definition of the Pauli-Lubanski (PL) vector is ##\textbf{W}=\star(\textbf{J}\wedge\textbf{P})=\star\left[(\textbf{M+S})\wedge\textbf{P}\right]## where ##\textbf{J},\textbf{M}\equiv\textbf{X}\wedge\textbf{P},\textbf{S}## are respectively the total, the orbital, and the internal/intrinsic/spin angular momenta of the particle. And as you note, because ##\textbf{P} \wedge \textbf{P} = 0##, the PL vector reduces to ##\textbf{W}=\star(\textbf{S}\wedge\textbf{P})## and hence depends solely on the spin angular momentum.
What would be the explicit formulation of ##\textbf{S}## in the spacetime algebra?
The spin angular momentum ##\textbf{S}## is a set of finite matrices whose dimension depends on the specific particle. For example, a Dirac spin-##\frac{1}{2}## fermion has ##\textbf{S}=\frac{i\hslash}{4}\left(\boldsymbol{\gamma}\wedge\boldsymbol{\gamma}\right)##, where the components of the vector ##\boldsymbol{\gamma}## are the four 4x4 Dirac gamma matrices ##\gamma_{\mu}\,##. In tensor notation, the total angular-momentum operator of a Dirac particle thus takes the form:$$J_{\alpha\beta}\equiv M_{\alpha\beta}+S_{\alpha\beta}=i\hslash\left(x_{\alpha}\partial_{\beta}-x_{\beta}\partial_{\alpha}\right)+\frac{i\hslash}{2}\left(\frac{\gamma_{\alpha}\gamma_{\beta}-\gamma_{\beta}\gamma_{\alpha}}{2}\right)$$
