Bob, thanks. You have the 1st one.
Kennalj, I should have added more explanation (the original paper of Sommerfeld explained this in detail).
It is very interesting that the solution of the Bohr-Sommerfeld model
which doesn't have the electron spin at all is completely
consistent with the solution of the Dirac equation which contain
the spin-orbital interaction.
Strange to say, there are many "accidental coincidences" in the development of QM.
About the quantization of Sommerfeld model, see also
this thread. (there is a little difference in the expression of the angular momentum).
The first condition is,
p_{\varphi}=mr^2 \dot{\varphi}, \quad m=\frac{m_{0}}{\sqrt{1-\beta^2}}, \quad \beta=\frac{v}{c}
Change the rectangular coodinates into the polar coordinates,
x = r cos \varphi, \qquad y = r sin \varphi
The nucleus is at the origin. The equation of motion is (the Coulomb force condition),
\frac{d}{dt}m\dot{x}= - \frac{kZe^2}{r^2}cos \varphi, \quad \frac{d}{dt}m\dot{y}= - \frac{kZe^2}{r^2}sin \varphi
Using the next condition (the angular momentum p_{\varphi} is the constant),
\frac{d}{dt}= \frac{d\varphi}{dt} \frac{d}{d\varphi}= \frac{p_{\varphi}}{mr^2} \frac{d}{d\varphi}
So the equation of the motion is (u= 1/r),
\frac{d}{dt}m\dot{x}= - \frac{p_{\varphi}^2}{mr^2}(u+\frac{d^2 u}{d\varphi^2}) cos \varphi
In the case of y, change the upper cos into sin. Combine this with the Coulomb force condition,
\frac{d^2 u}{d \varphi^2}+u = \frac{kZe^2 m_{0}}{p_{\varphi}^2} \frac{1}{\sqrt{1-\beta^2}}
Using the energy W (of #4) and erase the \beta, the solution can be expressed as,
u = \frac{1}{r} = C (1+ \epsilon cos \gamma \varphi)
And, the condition of the quantization is, (using the partial integration)
\oint p_{r}dr= p_{\varphi} \epsilon^2 \gamma \oint \frac{sin^2 \varphi d \varphi}{(1+\epsilon cos \varphi)^2} = p_{\varphi} \gamma \oint (\frac{1}{1+\epsilon cos \varphi}-1) d\varphi=n_{r} h
And, we should use the following mathematical formula, too,
\frac{1}{2\pi} \oint \frac{d \varphi}{1+ \epsilon cos \varphi} = \frac{1}{\sqrt{1-\epsilon^2}}
Combine all, the result of the energy W is obtained.
