The speed of sound at different tempertures
In summary, the speed of sound in air does not increase as the temperature becomes closer to absolute zero. In fact, the speed decreases as the temperature decreases. This is due to the decrease in molecular motion at lower temperatures. The commonly used equation for the speed of sound in air is only accurate for temperatures between 0 and 100 degrees Celsius, and a more accurate expression can be found using the ideal gas law.
gateman234
does the speed of sound increase as the temperture becomes closer to absolute zero, which would make the substance more and more dense?
dont think there is any
really confused as, isn't it the more dense a substance is the faster sound travels as particle colisions are faster, but while the temperture decreases the particle don't move as much
Check this page out. There's a simple equation that models the temperature dependence of sound in air (I assume you're talking about air and not some other substance).
http://www.glenbrook.k12.il.us/gbssci/Phys/Class/sound/u11l2c.html
But the disclaimer says:
The above equation relating the speed of a sound wave in air to the temperature provides reasonably accurate speed values for temperatures between 0 and 100 Celsius. The equation itself does not have any theoretical basis; it is simply the result of inspecting temperature-speed data for this temperature range.
And as he's talking about going 273 degrees below 0, it won't hold accuracy.
Ah, I read the OP wrong. I was thinking he was going to 0 C.
Look instead at the following page.
http://en.wikipedia.org/wiki/Speed_of_sound
In the section entitled "Speed in ideal gases and in air" they give an expression for [itex]c_{ideal}[/itex], the speed of sound in an ideal gas as a function of temperature (this temperature is in Kelvins). This equation applies down to absolute zero.
From the first website I gave you:
It would seem that this statement is wrong, because the Wiki page does in fact derive it as an approximation of the earlier expression for [itex]c_{ideal}[/itex], which comes from the ideal gas law!
1. How does temperature affect the speed of sound?
As temperature increases, the speed of sound also increases. This is because sound travels faster through warmer air, which has more energy and therefore allows sound waves to travel more quickly.
2. Does humidity affect the speed of sound?
Yes, humidity can affect the speed of sound. Higher levels of humidity can cause sound waves to travel slower due to the water molecules in the air interfering with the sound waves. Dry air allows sound waves to travel more easily and quickly.
3. What is the relationship between temperature and the speed of sound?
The relationship between temperature and the speed of sound is directly proportional. This means that as temperature increases, the speed of sound also increases, and vice versa.
4. How does altitude affect the speed of sound?
As altitude increases, the speed of sound decreases. This is because the air at higher altitudes is colder and less dense, making it harder for sound waves to travel through. This is also why sound travels faster at sea level compared to higher altitudes.
5. What is the speed of sound at different temperatures?
The speed of sound varies at different temperatures. At room temperature (around 20°C or 68°F), the speed of sound is approximately 343 meters per second (m/s). At higher temperatures, it can reach up to 349 m/s, and at lower temperatures, it can decrease to around 331 m/s.
10K
