I The Units of the Cosmological Constant: eV^2
Safinaz
TL;DR Summary
A question about the unit and the value of the cosmological constant
In natural units, it’s known that the unit of the cosmological constant is ##eV^2##.
I don‘t get why in this paper :
https://arxiv.org/pdf/2201.09016.pdf
page (1), it says the value of ##\Lambda \sim meV^4##, this means ##\Lambda \sim (10^6 ~ eV)^4 \sim 10^{24} eV^4 ##, shoud not the unit ##eV ^2 ## instead ?
Because in natural units the dimension of the cosmological constant is energy^4 and it is not known that the dimension is energy^2.
Safinaz said:
Summary: A question about the unit and the value of the cosmological constant
Safinaz said:
See for instance the discussion here:
https://www.quora.com/Why-is-the-cosmological-constant-without-units
Or this paper : https://arxiv.org/pdf/hep-th/0012253.pdf, equation (2)
They say the units of ##\Lambda## is ##eV^2 ## or equivalently in natural units ##cm^{-2} ## or ##sec^{-2}##
Ok, so the confusion is regarding ##\Lambda## vs ##\rho_\Lambda##. I was referring to ##\rho_\Lambda##, the energy density of the cosmological constant. The first paper you cite in the OP is discussing the scale of the energy density, the others discuss the constant appearing in front of the metric in the Einstein field equations. These differ by a constant ##8\pi G## and ##G## has dimensions energy^-2 in natural units.
Likes Ibix and Safinaz
In such cases it's always good to go back to SI units first. From the Einstein equations you read off that ##\Lambda## has the same units as ##[G E]/(V^4 L^3)## (##G## gravitational constant, ##V## dimension of velocity, ##L## dimension of length). The gravitational constant itself has the dimension of ##[E] L/M^2## and thus ##[\Lambda]=1/L^2##. In "natural units" with ##\hbar=c=1## that means it dimension ##\text{eV}^2##.
A different way to see it is to realize that ##\Lambda c^4/(8 \pi G)=u_{\Lambda}## is an energy density (density of "dark energy"). Often you see also ##\rho_{\Lambda}=\Lambda c^2/(8 \pi G)##, which is the corresponding "mass density", i.e., ##\rho_{\Lambda}=u_{\Lambda}/c^2##.
Likes Safinaz, Bandersnatch, Ibix and 2 others
OK, so this has bugged me for a while about the equivalence principle and the black hole information paradox. If black holes "evaporate" via Hawking radiation, then they cannot exist forever. So, from my external perspective, watching the person fall in, they slow down, freeze, and redshift to "nothing," but never cross the event horizon. Does the equivalence principle say my perspective is valid? If it does, is it possible that that person really never crossed the event horizon? The...
In this video I can see a person walking around lines of curvature on a sphere with an arrow strapped to his waist. His task is to keep the arrow pointed in the same direction How does he do this ? Does he use a reference point like the stars? (that only move very slowly) If that is how he keeps the arrow pointing in the same direction, is that equivalent to saying that he orients the arrow wrt the 3d space that the sphere is embedded in? So ,although one refers to intrinsic curvature...
ASSUMPTIONS 1. Two identical clocks A and B in the same inertial frame are stationary relative to each other a fixed distance L apart. Time passes at the same rate for both. 2. Both clocks are able to send/receive light signals and to write/read the send/receive times into signals. 3. The speed of light is anisotropic. METHOD 1. At time t[A1] and time t[B1], clock A sends a light signal to clock B. The clock B time is unknown to A. 2. Clock B receives the signal from A at time t[B2] and...
