The Vacuum Fluctuation Myth - Comments
220 replies · 28K views
RockyMarciano said:
This is purely semantic but both the insight and thread are about semantics so why not get it right?. Fluctuation is a word that is synonim both of oscillation and of indeterminacy or uncertainty. All it means in the quantum context is the Heisenberg indeterminacy of the ground state, and what fluctuates(vacillates i.e. it is intrinsically uncertain) is precisely the noncommuting observables. Of course many people by extension thinks about something moving or oscillating, that I guess it is what you understand if you disregard the meaning of fluctuation as vacillation/indeterminacy. Since Heisenberg indeterminacy lies at the heart of the quantum departure from classical physics, quantum fluctuations by extension are also referred by many as this departure from classicality.
On the other hand if one is strict with the math not even the fields or the waves actually oscillate, since the math always describes a rigid picture, a shortcoming of analysis. But this should show just how ridiculous can blind strictness get.
But it seems vacuum fluctuation is mentioned more in QED and you are talking about "quantum fluctuations"
https://en.wikipedia.org/wiki/Quantum_fluctuation
https://en.wikipedia.org/wiki/QED_vacuum
https://en.wikipedia.org/wiki/Vacuum_polarization
so some "fluctuation" is related to vacuum in the vicinity of interactions others to an otherwise empty interstellar vacuum. It sound like many concepts being mixed up.
No. Fluctuation in today's usage always means change, not just being uncertain! All the major dictionaries agree on that:
http://www.dictionary.com/browse/fluctuation
1. continual change from one point or condition to another.
2. wavelike motion; undulation.
3. Genetics. a body variation due to environmental factors and not inherited.
http://dictionary.cambridge.org/dictionary/english/fluctuate
fluctuate: to change, especially continuously and between one level or thing and another
https://en.oxforddictionaries.com/definition/fluctuation
An irregular rising and falling in number or amount; a variation
https://www.merriam-webster.com/dictionary/fluctuate
fluctuate:
1. to shift back and forth uncertainly
2. to ebb and flow in waves
https://www.vocabulary.com/dictionary/fluctuation
The noun fluctuation refers to the deviations along the path from one point to another. We see frequent fluctuations in the stock market, as prices go up or down, and also in the weather, which is always changing.
http://www.macmillandictionary.com/dictionary/british/fluctuation
frequent changes in the amount, value, or level of something
Even wikipedia describes it as a change, though in a completely unscientific manner (not surprisingly, since it also promotes lots of other nonsense about virtual particles):
''In quantum physics, a quantum fluctuation (or quantum vacuum fluctuation or vacuum fluctuation) is the temporary change in the amount of energy in a point in space [...] the field's lowest-energy or ground state, often called the vacuum state, is not, as one might expect from that name, a state with no particles, but rather a quantum superposition of particle number eigenstates with 0, 1, 2...etc. particles.''
The quality of the Wikipedia statement can be assessed from the second sentence quoted, which is absurd. The vacuum state is always the eigenstate of the number operator with exactly zero particles. There is no uncertainty in the number of particles, since it is an eigenstate.
This is only your private interpretation of the term. Never before I heard of someone talk about quantum vaccilations! And even that word means not just uncertainty but wafering uncertainty - a process in time!
Arnold
What do you think this statement is saying then in wiki
"So what does the spacelike part of the propagator represent? In QFT the vacuum is an active participant, and particle numbers and field values are related by an uncertainty principle; field values are uncertain even for particle number zero. There is a nonzero probability amplitude to find a significant fluctuation in the vacuum value of the field Φ(x) if one measures it locally (or, to be more precise, if one measures an operator obtained by averaging the field over a small region)."
https://en.wikipedia.org/wiki/Propagator
As stated, it is meaningless since ##\Phi(x)## is not an operator, hence not an observable. As remarked in your quote, one has to use a smeared version (averaging over a small open region in space-time) to produce an operator. Even with this amendment, the statement is misleading. The ''vacuum value'' is not a commonly used expression. The nearest expression with a formal meaning is the vacuum expectation value, but this is completely determined and hence certain. What is probably meant is that if one could measure the local value of a smeared field in the vacuum state (don't ask how this ever can be done, as the vacuum contains no particles, hence no observer), the result would have a significant uncertainty, i.e., there is a nonzero probability of getting a result significantly different from the vacuum expectation value. This is formally true if one assumes (as is commonly done) that the Born interpretation holds in this (counterfactual) case.
But in the statement quoted, the mistake already pointed out is made - that uncertainty and fluctuation are equated. This turns an unconspicuous statement that some measurement result has a significant uncertainty (we know this holds for most measurements) into the remarkable and wrong statement that the value fluctuates - with the implied, equally wrong consequence that the vacuum is ''active''. This is typical for the exaggerations made when turning banal truths into exciting stories for everyone.
The passage
''In terms of virtual particles, the propagator at spacelike separation can be thought of as a means of calculating the amplitude for creating a virtual particle-antiparticle pair that eventually disappear into the vacuum, or for detecting a virtual pair emerging from the vacuum. In Feynman's language, such creation and annihilation processes are equivalent to a virtual particle wandering backward and forward through time, which can take it outside of the light cone.''
from the same wikipedia article is also misleading. Creation and annihilation operators only exist for time-like, on-shell momenta; hence the associated creation and annihilation processes all refer to real particles.
The term uncertainty or indeterminacy is obviously related to change, change in measuring expectations, have you heard about statistical fluctuations referred to the uncertainty in measurements? I mean that's QM.
Frankly, it looks as though you stubbornly need to hold on to your straw man and the mantra "nothing fluctuates" (indeed a quite private interpretation), when everybody knows since Heisenberg's first modern quantum mechanics paper, the concept of conjugate observables fluctuating as described by Fourier transform coefficients and outlined by Born in its probabilistic rule to capture just that fluctuation in the measurement of noncommuting observables, so hardly my own private interpretation.
This is nonsense. In a stationary setting (such as the ground state of a quantum system), expectations are constant, not fluctuating.
Measuring expectations means making a lot of individual measurements of different realizations of the same system and taking their mean. Each measurement deviates from the mean, and the minimal mean square deviation is quantified by the uncertainty relation.
The fluctuation is neither in the quantum system nor in the expectation but in the series of measurements. It is due solely to the measurement process. It comes from the fact that each time a different particle is measured.
But when you measure a field there is only one field so nothing that could fluctuate. Unless the field itself fluctuates - i.e., changes its values rapidly in time like in turbulence. But a free field in the vacuum state is far from turbulent.
I wasn't using the word expectation technically, as referred to expectation values there. I was referring to what you explain below(so I'm happy that you got my meaning right after all) and this applies irrespective of the states being stationary or not.
By the way, even if using your biased concept of the word fluctuation referring only to oscillation, are you saying that stationary waves are not oscillating? I guess they are not waves then either.
I see you have finally understood what quantum fluctuations mean, This minimal mean square deviation refers to something changing(in this case the conjugate noncommuting variables), or there would be no minimal square deviation. So see, it was not so difficult to see how it is this uncertainty that using the statistical language of QM is referred by some people as quantum fluctuation
Sure, that is where the fluctuation called quantum fluctuation in QM is(I'm leaving out the quantum field extension of the term for reasons I explained in a previous post) and yes, that is the process it is due to.
A. Neumaier said:
The Heisenberg uncertainty relation is not about quantum fluctuations but about the intrinsic uncertainty in measuring noncommuting observables.
I would argue that it is not about the measurement. The state itself has this uncertainty. If it would be an issue of the measurement, you could try to find measurements that avoid this uncertainty (like measuring entangled particles and so on - I'm sure you know all those ideas). But we know that no measurement, no matter how clever, can avoid it.
No. The noncommuting observables are fixed, hence do not change ate all; in the textbook case of Heisenberg's uncertainty relation, they are always ##p## and ##q##. . Only the measurement results change, under repeated measurement of similarly prepared systems. As long as nothing is measured, nothing fluctuates!
They are oscillating, of course, but not fluctuating. In physics, the latter means unpredictable changes. The oscillations of a stationary wave are very predictable.
In principle the (pure or mixed) state can be prepared and measured to arbitrary accuracy (e.g., by quantum tomography), hence has no uncertainty in itself. It just encodes the uncertainty revealed by potential measurements.
mfb said:
IIf it would be an issue of the measurement, you could try to find measurements that avoid this uncertainty (like measuring entangled particles and so on - I'm sure you know all those ideas). But we know that no measurement, no matter how clever, can avoid it.
How do we know it? Only because the Heisenberg relations says so. This means that no matter how hard we try, we cannot avoid uncertainty in individual measurements.
We can say the position of a particle is uncertain but this doesn't make it fluctuating. If we measure once we don't see any fluctuation, just a definite value deviating from the mean. measuring twice is usually impossible (except for nondemolition measurements of conserved variables - which then don't fluctuate by definition).
For stationary beams (i.e., identically prepared particles), fluctuations are always fluctuations of measurement results on different realizations of the system. But if no measurements are taken there are no fluctuations. In some very respectable interpretations of quantum mechanics it is even meaningless to assign definite values to a system when it is not measured! How can a nonexistent value fluctuate?
For most physicists I know the Heisenberg's uncertainty is intrinsic and independent of the measurement process
If nothing is measured you don't have a physical theory.
You have managed to shift the meaning you attributed to the word fluctuation to make it indistinguishable with mine here(unpredictability in the sense of uncertainty in position and momentum, if you apply the word to the quantum uncertainty relations you'll know what serious people mean by "quantum fluctuations" in nrqm). But I'm sure you think you are right and I'm wrong so feel free to go on with your "nothing flutuates" mantra.
stevendaryl said:
I am not sure that there is any actual content to the question: "Does anything really fluctuate in the ground state?" To answer it requires going beyond the wave function to an interpretation.
Possibly yes. If this is true then asserting that quantum fluctuations exist has no content either. Thus quantum fluctuations do not exist in any meaningful sense. Except perhaps in interpretations such as Bohmian mechanics that postulate the existence of variables that are in principle unobservable - since everything observable must be formulated in orthodox quantum mechanics in order not to make deviating predictions.
But then the uncertainty relation is a purely theoretic statement about mathematical expectation values - not one about fluctuations where something changes in an unpredictable way. The only way to relate it to change is by relating it to changing measurement results.
We have a good physical theory about what happened inside stars and on the Earth eons ago.
Long before there were physicists to measure anything and long before people who dared to assert that if nothing is measured you don't have a physical theory!
You are confusing measurements with observers. My statement just indicates that without measurement(as a concept which is nothing but the possibility of interaction) you don't have a physical theory, only a mathematical construct instead with no connection with nature, that seems to be what you have in mind. Without interactions there are no physics.
By the way, only measurements, either direct or indirect can tell us if our theory of the star's core is good or not. One doesn't need to go inside the star, that is a quite naive view of what measurements are.
This is again a very nonstandard way of using physical terms. Nobody but you calls the mere possibility of interaction a measurement. Please do some serious reading about measurement before continuing discussion!
Agreed. I said most physicist, not necessarily my opinion.
If you really think measurement has nothing to do with interacting is true that is not worth to continue the discussion. I didn't define it as "the possibility of interaction", I said that measurement implied the possibility of interaction, how do you measure anything without interacting with it?
RockyMarciano said:
measurement [...] I didn't define it as "the possibility of interaction", I said that measurement implied the possibility of interaction, how do you measure anything without interacting with it?
Well, then learn tocorrectly use the English language. Saying
will be understood by everyone as implying ''measurement is nothing but the possibility of interaction''!
Measurement is needed to check theories. But when they are checked they are applied in many, many unchecked and uncheckable instances, to make inferences. These inferences come out true if the theory is correct. If, in order to trust a theory, we would have to check all inferences from it by new measurements, the theory would be more than worthless.
Thus a good theory works correctly no matter whether or not something is measured, and is applied no matter whether or not something is measured. In particular quantum mechanics. But the only times something fluctuates (outside of turbulent or stochastic processes) is when one actually makes multiple measurements on similarly prepared systems. Thus fluctuation is related to actual measurement and not to the mere possibility of interaction.
RockyMarciano said:
[...] is not worth to continue the discussion.
True, and I'll stop the discussion with you here since it is boring to others to have to endlessly repeat myself.
How do you prepare a state that has well-defined position and momentum at the same time? As in: if you choose to measure one of them at random, you can be sure what you will measure. If you agree that this is impossible, how is that not an uncertainty of the state itself?
Well, now some are eliminating too many fluctuations. I agree with the statement that it's not the vacuum that fluctuates. To the contrary it's the very state that is stable under time evolution. There's nothing and it stays nothing, and this nothing is Poincare invariant. You cannot "perturb the nothing" without introducing something, and that's the key to resolve the quibbles the formal-QFT lovers (and I'm counting myself to them). Just omit "vacuum" and just say fluctuations, and indeed everything is fine, i.e., indeed the electromagnetic field fluctuates as well as the charges in a well-defined sense, i.e., the vacuum expectation value of e.g., the electromagnetic field vanishes but not its square.
The Lambshift is not due to fluctuations of the vacuum but the fluctuations of the charges (in the case of the hydrogen atom of the protons and electrons) and the electromagnetic field, and quantitatively these fluctuations are defined within perturbation theory, which can be very elegantly and precisely expressed in terms of Feynman diagrams which have a certain intuitive appeal in the sense of mechanisms like "exchange of fields" (propagator lines) and "quantum fluctuations" (loops of propagator lines).
However, what's observable are the asymptotic free states. In the case of the Lambshift that's the initially somehow excited hydrogen atom which spontaneously emits a photon (em. wave) whose energy can be measured and doing this accurately enough (as did Lamb and Retherford in their very famous measurement, but not measuring spectral lines in the visible light but using a microwave resonator) you find the Lamb shift. As you see, you never ever can measure the vacuum state itself since of course you have to introduce something to measure it. In this case it's a hydrogen atom and a microwave resonator to excite the corresponding states. See, e.g.,
http://hyperphysics.phy-astr.gsu.edu/hbase/quantum/lamb.html
It's far from being vacuum! It's a beam of hydrogen atoms, microwave fields and a lot of other equipment to figure out the quantum corrections to the tree-level (Dirac quantum mechanics approximation), parts which in the theoretical analysis in terms of loop corrections of perturbation theory then are colloquially called "vacuum polarization", "vertex correction", etc. but one shouldn't take this too literally, what's done is to use an analysis in terms of perturbation theory, use a lot of tricky calculational tools to renormalize the first infinite integrals in a proper and physically sensible way etc.
There are no such states, so your first question is a meaningless request. The conundrum you pose arises from mixing classical thinking (where in the deterministic case a state means specified values of ##p## and ##q##) and quantum thinking, where a state means something quite different.
In general, both in classical and quantum mechanics, a state is a positive linear functional on the observable algebra. In quantum mechanics, the latter is the algebra of linear operators on a Schwartz space (as in the case of ##p## and ##q##), and states are therefore in 1-1 correspondence with density operators, positive linear integral operators of trace one. This density operator can be prepared and measured to arbitrary accuracy for sources producing sufficiently small systems such as photons or electrons. One cannot require more about preparing or measuring a state. Thus there is no uncertainty in the state itself.
However, there is an uncertainty in prediction the value of ##p## and ##q## from any exactly known state, given by the uncertainty relation. No matter how accurately the state is known, the values of ##p## and ##q## in a joint measurement cannot be predicted better than within this uncertainty.
What do you mean by that phrase, apart from that its measured values are inherently uncertain?
ftr said:
so is this statement in wiki also wrong
"In the modern view, energy is always conserved, but because the particle number operator does not commute with a field's Hamiltonian or energy operator, the field's lowest-energy or ground state, often called the vacuum state, is not, as one might expect from that name, a state with no particles, but rather a quantum superposition of particle number eigenstates with 0, 1, 2...etc. particles."
Yes, as I had mentioned already in post #32.
vanhees71 said:
No, by definition the vacuum state is the state of lowest energy. You have to be a bit careful, however which vacuum you refer to. Of course the free-particle vacuum is not the same as the fully interacting one! It's a highly non-trivial issue.
Not even the Hilbert spaces are the same, so one cannot express the objects in the interacting theory in terms of those of a free theory, except asymptotically.
But the vacuum in an interacting theory still contains no particles in any meaningful sense.
The natural ##N##-particle states (if one wants to define them at all) are - both in the free and in the interacting case - the states obtained by acting upon the vacuum with integrals over products of ##N## renormalized field operators. In the free case one can use the CCR or CAR to make a clean decomposition of these integrals into integral over normally ordered products of creation and annihilation operators and only the pure creation terms contribute. In the interacting case, this decomposition is no longer useful as the positive and negative frequency parts of the renormalized fields have no longer nice commutation properties.
For a very good treatment of scattering theory and the issue of wave packets and the uncertainty issue, see Messiah, Quantum Mechanics (it's non-relativistic, but the basic definitions are valid also in the relativistic case).
The question is about my statement that the electromagnetic field fluctuates. That's very clear since there's an uncertainty relation for the em. field, which follows immediately from the canonical equal-time commutator relations of ##\vec{A}##
$$[\hat{E}_i(t,\vec{x}),\hat{B}_j(t,\vec{y})]=-\mathrm{i} \epsilon_{ijk} \partial_k \delta^{(3)}(\vec{x}-\vec{y}).$$
But uncertainty is not the same as fluctuation. The latter is about an unpredictable process in time or space; the former is about the impossibility of an exact joint measurement.
