How to Calculate the Virial Theorem for a Particle Moving in a Potential?
Denver Dang
A particle is moving along the x-axis in the potential:
\[V\left( x \right)=k{{x}^{n}},\]
where k is a constant, and n is a positive even integer. \left| \psi \right\rangle is described as a normed eigenfunction for the Hamiltonoperator with eigenvalue E.
Show through the "Virial Theorem" that:
\[\begin{align}<br /> &amp; \left\langle \psi \right|\hat{V}\left| \psi \right\rangle =\frac{2}{n+2}E \\ <br /> &amp; \left\langle \psi \right|\hat{T}\left| \psi \right\rangle =\frac{2}{n+2}E, <br /> \end{align}\]<br />
where \hat{V}\ and \hat{T}\ denotes the operators respectively for potential and kinetic energy.
The Virial Theorem:
\[2\left\langle T \right\rangle =\left\langle x\frac{dV}{dx} \right\rangle \]
Well, I'm kinda lost.
I'm not sure how to calculate anything tbh...
The thing that confuses me, which is what I think I should do, is calculating:
\[\begin{align}<br /> &amp; \left\langle \psi \right|\hat{V}\left| \psi \right\rangle \\ <br /> &amp; \left\langle \psi \right|\hat{T}\left| \psi \right\rangle \\ <br /> \end{align}\]<br />
But can't find anything in my book that shows how to calculate anything that looks like that.
So a hint would be very helpful :)Regards
Start with
<br /> \left\langle \psi \right|\hat{H}\left| \psi \right\rangle = \left\langle \psi \right|\hat{T} + \hat{V} \left| \psi \right\rangle.<br />
What is the left side? What is the right side?
Sorry for the late reply...
But that is my problem. I'm not sure how to calculate that ?
Is it an integral, a commutator trick, or...? As I said, I can't seem to find anything in my book that shows how to calculate that.
Start at the beginning. What is
\left\langle \psi \right|\hat{H}\left| \psi \right\rangle?
Hint to George Jones' question:
##|\Psi|^2=\frac{1}{\sqrt{\pi b^2}}\exp(\frac{-(x-x_0)^2}{b^2}).## ##\braket{x}=\frac{1}{\sqrt{\pi b^2}}\int_{-\infty}^{\infty}dx\,x\exp(-\frac{(x-x_0)^2}{b^2}).## ##y=x-x_0 \quad x=y+x_0 \quad dy=dx.## The boundaries remain infinite, I believe. ##\frac{1}{\sqrt{\pi b^2}}\int_{-\infty}^{\infty}dy(y+x_0)\exp(\frac{-y^2}{b^2}).## ##\frac{2}{\sqrt{\pi b^2}}\int_0^{\infty}dy\,y\exp(\frac{-y^2}{b^2})+\frac{2x_0}{\sqrt{\pi b^2}}\int_0^{\infty}dy\,\exp(-\frac{y^2}{b^2}).## I then resolved the two...
Hello everyone, I’m considering a point charge q that oscillates harmonically about the origin along the z-axis, e.g. $$z_{q}(t)= A\sin(wt)$$ In a strongly simplified / quasi-instantaneous approximation I ignore retardation and take the electric field at the position ##r=(x,y,z)## simply to be the “Coulomb field at the charge’s instantaneous position”: $$E(r,t)=\frac{q}{4\pi\varepsilon_{0}}\frac{r-r_{q}(t)}{||r-r_{q}(t)||^{3}}$$ with $$r_{q}(t)=(0,0,z_{q}(t))$$ (I’m aware this isn’t...
Hi, I had an exam and I completely messed up a problem. Especially one part which was necessary for the rest of the problem. Basically, I have a wormhole metric: $$(ds)^2 = -(dt)^2 + (dr)^2 + (r^2 + b^2)( (d\theta)^2 + sin^2 \theta (d\phi)^2 )$$ Where ##b=1## with an orbit only in the equatorial plane. We also know from the question that the orbit must satisfy this relationship: $$\varepsilon = \frac{1}{2} (\frac{dr}{d\tau})^2 + V_{eff}(r)$$ Ultimately, I was tasked to find the initial...
