Theory questions about Newton's Laws and Gravitation
The discussion revolves around two physics problems related to Newton's Laws and gravitation. For the first problem, the user is confused about the orbital period of two planets, questioning whether the second planet, with an orbit four times larger, would take four times longer to complete one revolution. The response clarifies that the relationship between orbital period and radius is not straightforward and requires further analysis. In the second problem, concerning two blocks connected by a cord on a frictionless surface, the user is unsure about calculating tension and the effects of acceleration without friction. Participants emphasize the importance of determining acceleration to find the tension and note that frictionless scenarios are often simplified for educational purposes.
ohsolost
I'm trying to figure out these two problems and I'm so lost!
1. Two planets are circling a star. The second planet has an orbit 4 times the size of the first planet. By the time the first planet revolves once, how many times the second one will?
My solution: the formula is T=2PiR/v... so wouldn't the second planet take 4 times as long?
2. Two blocks, which both have the mass of 3kg, are lying on a frictionless surface and are connected by a massless cord. One block is being pulled to the left with a force of 2.5N, and the other block is being pulled to the right with a force of 11.5N. What is the tension of the cord?
My solution: Since there's no friction, don't I just subtract the two forces?
What's the relationship between the tangential speed v, and the radius of the circular motion under the influence of the gravitational force? They depend on each-other, the answer to question #1 is not trivial.
Welcome to PF.
For 2, you need to determine the acceleration that the system is subjected to. Then you can apply that to the tension between the blocks
Thanks.Doesn't something weird happen to acceleration when there's no friction?
Weird. Like no resistance to motion weird?
Then yes. Frictionless only seems to happen in physics homework problems.
For 2) you could treat the smaller force as though it were out-sized friction on the second block only.
I multiplied the values first without the error limit. Got 19.38. rounded it off to 2 significant figures since the given data has 2 significant figures. So = 19. For error I used the above formula. It comes out about 1.48. Now my question is. Should I write the answer as 19±1.5 (rounding 1.48 to 2 significant figures) OR should I write it as 19±1. So in short, should the error have same number of significant figures as the mean value or should it have the same number of decimal places as...
Thread 'A cylinder connected to a hanging mass'
Let's declare that for the cylinder, mass = M = 10 kg Radius = R = 4 m For the wall and the floor, Friction coeff = ##\mu## = 0.5 For the hanging mass, mass = m = 11 kg First, we divide the force according to their respective plane (x and y thing, correct me if I'm wrong) and according to which, cylinder or the hanging mass, they're working on. Force on the hanging mass $$mg - T = ma$$ Force(Cylinder) on y $$N_f + f_w - Mg = 0$$ Force(Cylinder) on x $$T + f_f - N_w = Ma$$ There's also...
