Understanding Winter Thermal Conduction on Wooden Floors
In winter, wooden floors feel colder to the touch than rugs or carpets, despite both being at the same temperature, due to the higher thermal conductivity of wood. Heat is transferred from the warmer feet to the cooler floor more rapidly, making the floor feel colder. In contrast, rugs and carpets have low thermal conductivity, which minimizes heat loss and prevents the sensation of cold. The presence of air within these materials further reduces conductivity, enhancing their insulating properties. This phenomenon can be likened to an electrical potential divider, where materials with different conductivities affect heat flow and temperature perception.
queuetea
in winter, wooden floor feels cold to the barefoot but the rugs and carpets don not feel cold although the floor and carpet are at the same temperature?
Science news on Phys.org
Your feet are warmer than the floor, so heat is transported from your feet to the floor. Wood can do this quicker, therefore it feels colder.
and why for the rugs and carpets do not feel cold although the floor and carpet are at the same temperature?
The conductivity is so low that you do not notice the effect. Both have a lot of air (bad conductor) and wool (another bad conductor, especially as it contains more air inside).
okay thank you sir :)
Assume that the temperature of the inside of your foot is always the same and the temperature 'below the floorboards' is also the same. There will be a thermal gradient from your body tissue, across your skin, through any insulation and the floor. If the intermediate layer has low conductivity, the surface of your skin will have a higher temperature (It's not just an illusion) because there will be a greater temperature drop across the insulation layer and the overall rate of heat flow will be lower.
There is a direct analogue here with an electrical potential divider, consisting of a chain of resistors, where the PD is shared across the resistors. Inserting a high value of resistor in series with a resistor will reduce the total current, which will reduce the PD across the original resistor.
