How Do I Determine the Thermal Conductivity of Glass from My Graph?
To determine the thermal conductivity of glass from the provided graph, it's essential to correctly interpret the plotted values of lg temperature against time. The slope of the graph relates to the thermal conductivity, which is calculated using the formula k/Brx, where k, b, r, and x are constants. The initial temperature of 20°C complicates the calculation, as it does not yield a clear intercept on the graph. It's crucial to ensure that all units are consistent, specifically in watts per meter per Kelvin (W m^(-1) K^(-1)). Accurate unit management and a careful review of the slope will lead to the correct thermal conductivity value.
chickens
Hi there,...this isn't homework..its more to my practical...anyways...from the attachment given..that is the first page of my practical guide...the problem is...on the procedure part...it asked me to plot a graph of lg temp againts t ...if i do so...how do i get the thermal conductivity of glass as the initial temp is 20 C ?!?...so weird...because i don't get lg 20 as interception from the graph...btw..if i simply assume the gradient of graph plotted is kt/Brx ...then my thermal conductivity of glass is 0.2++...i don't think that's right :(...help me anyone..please
http://server2.uploadit.org/files/chickens-exp11.jpg
First of all
What is the unit. IT all depends on the units.
I think you need to look at the slope value again. It should be k/Brx since t is your independent variable and k,b,r and x are all constants. Also, pay heed to Gamma. Units will be your downfall if you are not careful.
oh..the units are all in W m^(-1) K^(-1)
Thread 'Trying to understand the logic behind adding vectors with an angle between them'
My initial calculation was to subtract V1 from V2 to show that from the perspective of the second aircraft the first one is -300km/h. So i checked with ChatGPT and it said I cant just subtract them because I have an angle between them. So I dont understand the reasoning of it. Like why should a velocity be dependent on an angle? I was thinking about how it would look like if the planes where parallel to each other, and then how it look like if one is turning away and I dont see it. Since...
