Thermal Conductivity: Exploring the Disparity in the Real World
In summary, there is a disparity between thermal conductivity and how it is observed in the real world. This is due to various factors such as the release of heat through natural convection and radiation, which can blur the differences in thermal conductivities of different materials. In small-scale experiments, the differences may not be significant enough to be observed.
sasuke07
54
I was wondering why there is such a disparity between thermal conductivty and how they act in the real world.
Ex. If if have 3 cups filled with hot water. The 3 cups are made of glass, plastic and metal.
The metal will obviously have way higher thermal conductivity compared to the glass and plastic cups. But the temp. goes down slowly in all 3 cups and the rate that the temp. goes down. between the 3 cups are similar. The metal will drop in temp. faster than the other 2 but not that much faster. I was wondering why
No Equations
Said in 1.
A cup loses heat through its walls as well as from its surface. Furthermore, in order for the sides to lose heat, the heat must be released via natural convection. Natural convection from horizontal surfaces is greater than it is from vertical surfaces (side of container). Natural convection is a relatively slow mover of heat so it tends to blunt the differences in thermal conductivities of the walls of the cup. What diffuses through the wall must be released to the surrounding air.
The cups also radiate energy. That must be a consideration as well. Water radiates.
Rates are similar in them but not equal. Probably your experiment and ambient is too small to judge any significant difference due to the nature of the matters. Rest is clarified by LawrenceC
Thanks a lot
person:
I can explain the disparity in thermal conductivity and its real-world application. While metals do have higher thermal conductivity compared to glass and plastic, it is important to consider other factors that affect the rate at which temperature decreases in a substance. One factor is the specific heat capacity of the material, which is the amount of heat needed to raise the temperature of a given mass by 1 degree Celsius. This means that even though the metal cup may have higher thermal conductivity, it may also have a higher specific heat capacity, requiring more heat to raise its temperature. Additionally, the thickness and surface area of the material also play a role in heat transfer. In the case of the cups filled with hot water, the metal cup may have a larger surface area, allowing for more heat to dissipate into the surrounding environment compared to the glass and plastic cups. Therefore, while thermal conductivity is an important factor in determining how quickly a material can transfer heat, it is not the only factor at play in real-world scenarios. Other factors such as specific heat capacity, thickness, and surface area must also be considered to fully understand the rate at which temperature decreases in different materials.
1. What is thermal conductivity and why is it important?
Thermal conductivity is the measure of a material's ability to conduct heat. It is important because it helps us understand how heat is transferred through different materials, which is crucial for designing and building efficient systems such as insulation, heating and cooling systems, and electronics.
2. How is thermal conductivity measured?
Thermal conductivity is typically measured by using a device called a thermal conductivity meter, which measures the rate of heat flow through a material. This involves applying a temperature difference across the material and measuring the resulting heat flux.
3. What factors affect thermal conductivity?
Thermal conductivity is influenced by several factors, including the type of material, its density, temperature, and moisture content. Generally, materials with higher densities and lower thermal resistivity have higher thermal conductivity.
4. What are some real-world examples of thermal conductivity in action?
Thermal conductivity plays a role in many everyday applications, such as cooking (heat transfer through pots and pans), building insulation (preventing heat loss), and electronics (dissipating heat from devices). It also influences natural phenomena, such as the movement of heat through the Earth's crust and atmosphere.
5. How does thermal conductivity impact energy efficiency?
The higher the thermal conductivity of a material, the more easily heat can pass through it. This can either be beneficial or detrimental depending on the situation. For example, in insulation, a low thermal conductivity is desired to prevent heat loss, while in electronics, a high thermal conductivity helps dissipate heat and prevent overheating. Understanding thermal conductivity is crucial for designing energy-efficient systems.
  • Thermodynamics
14K
12K
