Thermal energy to be dissipated in an hour
The discussion centers on calculating the amount of perspiration a basketball player needs to vaporize to dissipate an increase in thermal energy of 30.0 W during a game. The total thermal energy to be dissipated in one hour is calculated to be 1.08 x 10^5 J. The initial calculation suggests that approximately 0.0478 kg of water would need to be vaporized, using a heat of vaporization of 2.26 x 10^6 J/kg. However, it is noted that the heat of vaporization for water at 37 degrees Celsius is actually around 2.40 x 10^6 J/kg, which could affect the final result. The discussion emphasizes the importance of considering the starting temperature of perspiration in thermal energy calculations.
dani123
During the game, the metabolism of basketball players often increases by as much as 30.0 W. How much perspiration must a player vaporize per hour to dissipate this extra thermal energy? Assume that perspiration is simply pure water and that perspiration starts at temperature of 37 degrees celcius.
Q=mcΔT
Q=mHv
Thermal energy to be dissipated in 1.00h is
U=(30J/s)(3600s/h)=1.08x10^5J
The amount of water this energy transmittes as heat would vaporize is,
m=(1.08x10^5J)/(2.26X10^6J/kg)= 4.78x10^-2kg
----> Just looking for someone to double check my reasoning/calculations and to make sure the number of significant figures has been respected. Thank you so much in advance!
You don't seem to have taken into account the starting temperature of the perspiration.
your calculation for the energy needed to vaporize that amount of water is correct.
Hmm. The heat of vaporization for water varies with temperature. At the boiling point (100C) it's 2.257 x 106 J/kg, but at 37C it's more like 2.40 x 106 J/kg.
Thread 'Collision of a bullet on a rod-string system: query'
In this question, I have a question. I am NOT trying to solve it, but it is just a conceptual question. Consider the point on the rod, which connects the string and the rod. My question: just before and after the collision, is ANGULAR momentum CONSERVED about this point? Lets call the point which connects the string and rod as P. Why am I asking this? : it is clear from the scenario that the point of concern, which connects the string and the rod, moves in a circular path due to the string...
Thread 'A cylinder connected to a hanged mass'
