Thermal Expansion of Rod Problem
The discussion centers on calculating the rate of temperature change required for an aluminum rod to achieve a constant elongation speed of 86 nm/s over a heated section of 4.7 cm. The relevant equation for thermal expansion is e = aLT, where e is elongation, a is the coefficient of thermal expansion, L is the initial length, and T is the change in temperature. The correct rate of temperature change (dT/dt) is determined to be approximately 0.079 °C/s, derived from the relationship between elongation and temperature change using the coefficient of thermal expansion for aluminum, which is 24 x 10^(-6) °C^-1.
  • Understanding of thermal expansion principles
  • Familiarity with the coefficient of thermal expansion
  • Basic calculus for differentiation
  • Knowledge of unit conversions in physics
  • Study the derivation of the thermal expansion equation e = aLT
  • Learn about the properties and applications of aluminum in engineering
  • Explore advanced topics in heat transfer and temperature control
  • Investigate the implications of thermal expansion in different materials
Students in physics or engineering, particularly those focusing on materials science, thermal dynamics, and mechanical engineering applications involving thermal expansion.
MasterYoda100
In a certain experiment, it is necessary to be able to move a small radioactive source at selected, extremely slow speeds. This is accomplished by fastening the source to one end of an aluminum rod and heating the central section of the rod in a controlled way. If the effective heated section of the rod is 4.7 cm long, at what constant rate must the temperature of the rod be changed if the source is to move at a constant speed of 86 nm/s?
e = aLT, e=elongation, a = coefficient of thermal expansion, L = initial length, T = change in temperature
Since we are trying to determine the rate of change of temperature, I differentiated the equation for thermal expansion in terms of time: de/dt = aL(dT/dt)
The change in length with respect to time (de/dt) is equivalent to the velocity at which the rod is expanding (given as 86 x 10^(-9) m/s). We also know the coefficient of thermal expansion for aluminum (24 x 10^(-6) degC^-1) and the original length (.047 m). Solving for the rate of change of temperature (dT/dt), I got an answer of 0.0762411348 degC/s, however, this answer is incorrect. I am unsure as to where I am going wrong (all units seem correct). Any help would be most appreciated. Thanks.
That's the answer I get (with fewer significant figures) - assuming the rod quickly reaches a uniform temperature.
In 1s you want a change of 86nm in 4.7cm, which is 86e-9/0.047 = 1.89E-6
It lengthens by 24E-6 for each deg C so you want a change of 1.89E-6/24E-6 = 0.079deg/s
