Thermal expansion of steel pipe
The discussion focuses on the thermal expansion of a 40,000 km long steel pipe surrounding the Earth's equator when the temperature increases by 1 degree Celsius. The calculations reveal that the pipe expands by approximately 0.4 km, resulting in a new length of 40,000.4 km. This expansion leads to a change in the radius of the pipe from 6369.42 km to 6369.49 km, creating a height of 0.07 km above the ground. The participants confirm the calculations and emphasize the importance of precision in numerical values to avoid round-off errors.
  • Understanding of thermal expansion formulas, specifically ΔL = Lo x 1/100,000 x ΔT
  • Familiarity with basic geometry, particularly the relationship between circumference and radius
  • Knowledge of significant figures and their importance in calculations
  • Basic understanding of the Earth's dimensions, including its equatorial radius
  • Research the principles of thermal expansion in different materials
  • Explore advanced calculations involving thermal expansion in engineering applications
  • Learn about the impact of temperature changes on structural integrity in civil engineering
  • Investigate the effects of thermal expansion in large-scale infrastructure projects
Engineers, physicists, and students studying materials science or civil engineering, particularly those interested in the effects of temperature on structural components.
rwh
The equatorial radius of the Earth is about 6370km. Consider a 40,000 km long steel pipe that forms a giant ring that fits snugly around the equator of the earth. Suppose the temp. of the pipe is increases 1 degree C. The pipe gets longer. it is also no longer snug. How high does the pipe stand off the ground?
Assume that D L = L o x 1/100,000 x D T
. I came up with .07 km. The radius of the pipe is actually 6369.42 km. When the temperature of the pipe is increased 1 degree Celsius it will expand .4 km making the pipe 40000.4 km. 40000.4 / 3.14 = 12738.98. 12738.98 / 2 = 6369.49 (radius) 6369.49- 6369.42 is .07km.
Am I right?
yes, I believe so
Simpler yet ... (with DT = 1)
\Delta L = \Delta 2 \pi R = 2 \pi \Delta R = \frac{L_o}{ 100,000} = \frac {2 \pi R}{100,000}
Canceling 2pi on both sides :
\Delta R = \frac {R}{100,000} = 0.06369 ~km
Your number is a little high because of round off error. If your first significant digit is in the second decimal place, you want to calculate with numbers written up to at least 3 decimal places.
Thank you!
  • · Replies 19 ·
11K
14K
21K
  • · Replies 52 ·
  • · Replies 17 ·
19K
