Calculating Thermal Expansion of Water: Is the Formula Correct?
The forum discussion centers on calculating the thermal expansion of water using the formula ΔV = βV0ΛT. Participants highlight that the coefficient of volumetric thermal expansion (β) is not constant and varies with temperature, particularly emphasizing the need to use β as a function of temperature for accurate results. A specific example using β = 0.000207 from Engineering Toolbox yields a ΔV of approximately 1.9715 L for a 25L volume from 20°C to 100°C, which contradicts the expected 4% increase. The correct approach involves integrating β(T) over the temperature range to determine the change in volume accurately.
  • Understanding of thermal expansion principles
  • Familiarity with calculus, specifically integration
  • Knowledge of volumetric thermal expansion coefficients
  • Access to thermodynamic tables for water properties
  • Learn how to integrate functions in calculus, particularly in the context of thermal expansion
  • Study the variation of the coefficient of volumetric thermal expansion with temperature
  • Explore the use of thermodynamic tables for specific volume calculations
  • Investigate the application of the equation V=V0e^{∫[β(T')]dT'} for more accurate thermal expansion results
Researchers, engineers, and students in thermodynamics, particularly those focused on fluid dynamics and thermal properties of materials.
de_Sitter
Hello,
I'm trying to determine a way of calculating the thermal expansion of a volume of water. The formula I have come across is:
ΔV = βV0ΛT
The general consensus seems to be that water expands roughly 4% from 20°C to 100°C, or 4.2% from 4°C to 100°C (http://www.engineeringtoolbox.com/water-thermal-properties-d_162.html). Using β = 0.000214 as found on (http://www.engineeringtoolbox.com/cubical-expansion-coefficients-d_1262.html) the result of this formula is not around the expected 4% from 20 - 100°C. e.g. 25L gives ≈ 0.43 L increase.
Am I using the formula correctly? Some rudimentary examples use β as a constant, while others remark that β varies with temperature, but don't provide examples of using this in practice. Any suggestions would be appreciated.
Thank you.
Science news on Phys.org
CRC Hndbk. tables of density of water. Definitely not constant for water.
The coefficient of volume expansion varies with temperature. The equation is only supposed to apply in the vicinity of the base temperature. In your case, the coefficient is for around 20 C.
Chet
Hello,
Thank you both for your replies. I'm a little unconvinced that using the coefficient of the base temperature is correct. Using 25L from 20 to 100°C with coefficient 0.000207 as per (http://www.engineeringtoolbox.com/volumetric-temperature-expansion-d_315.html) I get ΔV = 1.9715 L, which is around a 7.8% increase, rather than the expected 4%, as given on (http://www.engineeringtoolbox.com/water-thermal-properties-d_162.html). Does anyone have an example of how they would model this increase?
To do it over a larger temperature range, you would have to know the thermal expansion coefficient as a function of temperature, and you would have to integrate.
de_Sitter said:
Hello,
You don't get that value for that coefficient of thermal expansion assumed constant over the temperature range. What you get is around 0.4 L or about 1.6%.
But you have a table with the variation of the coefficient with temperature right there. You can see that it increases with the temperature so it will be reasonable to get 4% over the whole range.
You can do an estimate by using these values.
Thank you all for your assistance. I'm a little rusty on my calculus, but Nidum's links are perfect for my purposes.
Thanks again!
So just to confirm I'm doing it right Chestermiller. I've fitted a curve to the data points given in some of the tables I linked earlier, which gives β(T). I then find the definite integral of this function over the temperature range (e.g 20°-100°C), then multiply by the initial volume?
ΔV = ∫[β(T)] dT ⋅ Vo , with 20° and 100° as the limits of integration
Basically correct for a small temperature change, but I would do it a little differently. The exact equation is:
$$\frac{1}{V}\frac{dV}{dT}=β(T)$$
So, integrating this equation, I get:
$$V=V_0e^{\int_{T_0}^T{β(T')dT'}}$$
where T' is a dummy variable of integration. This equation will give a more accurate result.
Chet
Thanks Chet, I'm not quite familiar with this dummy variable concept, but I'll do some reading. Thanks for the input.
  • · Replies 81 ·
  • · Replies 16 ·
14K
