Linear Expansion: Why Not Volume Expansion?
The discussion clarifies the concept of linear expansion versus volume expansion in materials, specifically using railway rails as an example. When heated, railway rails expand linearly due to their elongated shape, although they do experience volume expansion as well. The key takeaway is that while all dimensions of an isotropic material expand uniformly, the linear expansion is more noticeable in elongated objects because the change in length is significantly greater than the change in width or height. This phenomenon is explained using the formula ΔL = αL₀ΔT, where α represents the coefficient of linear expansion.
  • Understanding of thermal expansion concepts
  • Familiarity with isotropic and anisotropic materials
  • Knowledge of the coefficient of linear expansion (α)
  • Basic grasp of dimensional analysis in physics
  • Study the principles of thermal expansion in different materials
  • Learn about the coefficients of linear and volumetric expansion
  • Explore the implications of anisotropic materials in engineering
  • Investigate real-world applications of thermal expansion in construction and manufacturing
Students of physics, engineers in construction and materials science, and anyone interested in the thermal properties of materials will benefit from this discussion.
Milind_shyani
Hi,
I want to ask one question about linear expansion.
For eg if we take tke railway rails. then during summer due to the incresing heat the length of the rails increase. Now anything which has a mass has a volume so when the temperature of the metal rails increase during summer, why is it so that only linear expansion takes place in the rails why not VOLUME EXPANSION?
Science news on Phys.org
What makes you think that you can have linear expansion without volume expansion? (All three linear dimensions will expand, giving volume expansion.)
We say an object like rod expandlinearly coz it expansion in other dimensions is negligible compared to the linear one. Similar for a metal sheet or plate. But actually they all expand in all dimensions. I think an explanation to this is given in H C Verma
The percentage expansion is the same* for any linear dimension (in all directions); the actual change along any particular direction is of course proportional to the original length along that direction:
\Delta L = \alpha L_0 \Delta T
* for an isotropic material, of course
To be more precise: If the material is of a constant uniform composition, then it will expend equally in all directions. If the material is composed of different atoms oriented diversely with respect to an orthogonal set of axes, then the material is considered anisotropic, and the coefficients of expansion may vary depending upon the axis chosen. But in your steel rail example, it will expand uniformly in all directions; as one dimension is so much larger than the other, the net effects of the expansion along its length are more observable.
  • · Replies 16 ·
  • · Replies 22 ·
