Thermal Physics problem: Van der Waals
10 replies · 3K views · last reply
mmedrano8
1. Find an expression that relates T and V in a process in which the entropy S is constant, by doing the following:
a) From thermodynamic identity dS=(1/t)dU + (p/v)dV
find the expression for dS as a function of T and V (and dT and dV).
b) Integrate the expression found in (a) along the line of constant S.
I tried to use the equation of state for a Van der Waals gas
p=(NkT)/V-a(N^2/V^2)
a is constant
its energy as a function of temperature and volume is given by
U(T,V)=2NkT-a(N^2/V)
If you could give any hints that would be great!
That equation is dimensionally inconsistent and therefore wrong.
But it's just one letter aaway from right so is probably a typo. Anyway, fix it.
Are you allowed to assume an ideal gas?
I took a a snapshot of the problem to be more specific
  • Typed homework problem 3 on a Van der Waals gas: equation of state p = NkT/V - aN^2/V^2, energy U(T,V) = 2NkT - aN^2/V, then parts I (a, b) and II on entropy and adiabatic volume.
As noted by rude man, the equation given for dS is incorrect. Since the equation is just a simple rearrangement of the first law (with dQ = T dS), you can see how to fix it.
To proceed with the problem, you will need to use the expression for U and find it's differential dU in terms of dT and dV.
OK.
You're given U(T,V) and dS = 1/T dU + p/V dV
so taking dU is just basic calculus. N, k and a are constants.
Warning: I've carried this thru to dS = 0 in terms of T and V but I wind up with an expression that I can't integrate (tried separation of parts, couldn't do it). Someone else help!
ok so thermodynamic identity --> dS=(1/T)dU + (p/T)dV
Good.
What does this expression for dS become after substituting for dU and simplifying?
Hey, how come everyone except I caught the misstatement in the problem? Now I got to start over ... :
I hope at least U(T,V) is given correctly. Someone else want to check dimensions?
Still can't seem to separate variables though ...
ok dU=(∂U/∂T)dT + (∂U/∂V)dV --> dU = 2NKdT + aN^2(1/V^2)dV
I plug in P and dU into dS = (1/T)dU + (P/T)dV
I get...
dS = (1/T)[2NkdT + a(N^2)/(V^2)dV] + (NKT/V - (aN^2)/(V^2))/T)dV
please correct me if I am wrong but since S is constant, then dS equals 0,
therefore the lefthand side is 0, we separate the varibales for dT and dV and simplify
i get
-2dT=(T/V)dV
integrate both parts and solve for Vf --> Vf=Vi/16
Thanks so much guys!
Congartulations! Would you (or TSny or whoever) mind posting how you did the separation of variables? I couldn't do it. :blushing:
EDIT: never mind, I hadn't noticed two terms canceling each other, leaving only 2 terms to be separated.
Good show!
i forgot a step, -2dT = (T/V)dV --> (-2/T)dT=(1/V)dV
but i separated varibles by putting all T's and V's on opposite sides of the equation
-(1/T)[2NkdT] = (1/T)[a(N^2)/(V^2) + NKT/V - (aN^2)/(V^2))/T)dV
simplify a bit...
2NkdT = (NKT/V)dV
2dT = (T/V)dV
(2/T)dT = (1/v)dV then integrate both sides ---> 2ln(Tf/Ti) = ln(Vf/Vi) , where Tf = 4Ti , 2ln(4) = ln(Vf/Vi)
then solve for Vf
