Thermal Radiation: Measurement & Conversion Help
The discussion revolves around the use of a Radiation Pyrometer for measuring temperature and radiation, specifically focusing on the conversion of voltage measurements to radiation values. Participants explore the application of Planck's law in contexts where the target is not a black body, raising questions about emission grades and the accuracy of measurements.
  • One participant describes their use of a Radiation Pyrometer and expresses difficulty in converting voltage measurements to radiation values.
  • Another participant suggests that if the target is a black body, radiation depends solely on temperature and surface area, and recommends using Planck's law for calculations.
  • The original poster clarifies that their target is not a black body and questions whether Planck's law can still be applied, expressing uncertainty about the appropriate emission grade to set.
  • A later reply advises contacting the manufacturer for guidance on using the pyrometer with non-black body targets.
Participants have not reached a consensus on the applicability of Planck's law for non-black body measurements, and there are competing views regarding the best approach to take in this context.
There is uncertainty regarding the definition of emission grades and how they affect the application of Planck's law in this scenario. The discussion does not resolve the mathematical steps needed for accurate conversion.
lia123
hallo to all,
i use a Radiation Pyrometer to measure temperature and Radiation
Trough a datalogger i get those measurements in Volt
i am able to convert the Volt back in the temperature but in Radiation it is more difficult
i found the Plancksche function, but i do not really understand that
can anybody help me?
thanks in advance!
best regards
Science news on Phys.org
Describe your pyrometer.
If the target is a black body, then the radiation only depends on the temperature and surface area. If you know the temperature, then plug it into Planck's law to get the brightness (as a function of wavelength or frequency).
It is a Pyrometer from Heitronics, KT19.XX Series
My target is not a black Body, for testing i measure now in the Office the door/wall. Later it will be used to measure Vegetation.
I´m also not sure which emissiongrade i should set. Can i use Planck`s law, although i measure not a black Body? Is the function the same?
Thank you guys so much!
Best regards
I think you should email the manufacturer and ask about this.
  • · Replies 32 ·
  • · Replies 152 ·
12K
  • · Replies 19 ·
