(Thermo 3D) Power needed to maintain temp
To maintain an internal temperature of 25 degrees Celsius in a cube of water with glass walls at an external temperature of 20 degrees Celsius, the power required can be calculated using the equation P = (kA/L)(Tf-Ti). Assumptions include uniform temperatures in the water and air, and zero thermal resistance between the water and glass, as well as between the glass and air. The discussion emphasizes the importance of ensuring that units for thermal resistance align with those for surface area and thickness. By simplifying the problem with these assumptions, the calculation becomes more manageable. Understanding these principles is crucial for accurately determining the power needed for temperature maintenance.
jerrythewhale
If we have a cube full of water and glass walls, with an external environmental temperature of 20 degrees celsius, what is the power required to maintain an internal temperature of 25 degrees celsius?
Assume sides are 50cm.
I don't know what to do, I was trying out the P = (kA/L)(Tf-Ti) equation, but due to lack of experience, I don't know how to apply it when you have three mediums (air, glass, and water). Please help?
You will probably have to make some assumptions. For example you could assume..
1) The water is stirred so that the temperature is a uniform 25C.
2) Likewise the air outside is also stirred so that all the air in contact with the glass is 20C.
3) The thermal resistance between water and glass is zero.
4) The thermal resistance between glass and air is zero.
Then it simplifies to..
Power = Thermal Resistance of glass * (surface area/thickness of glass) * (Twater - Tair)
Make sure the units for the thermal resistance of glass match those for the surface area/thickness.
The rope is tied into the person (the load of 200 pounds) and the rope goes up from the person to a fixed pulley and back down to his hands. He hauls the rope to suspend himself in the air. What is the mechanical advantage of the system? The person will indeed only have to lift half of his body weight (roughly 100 pounds) because he now lessened the load by that same amount. This APPEARS to be a 2:1 because he can hold himself with half the force, but my question is: is that mechanical...
Some physics textbook writer told me that Newton's first law applies only on bodies that feel no interactions at all. He said that if a body is on rest or moves in constant velocity, there is no external force acting on it. But I have heard another form of the law that says the net force acting on a body must be zero. This means there is interactions involved after all. So which one is correct?
Thread 'Beam on an inclined plane'
Hello! I have a question regarding a beam on an inclined plane. I was considering a beam resting on two supports attached to an inclined plane. I was almost sure that the lower support must be more loaded. My imagination about this problem is shown in the picture below. Here is how I wrote the condition of equilibrium forces: $$ \begin{cases} F_{g\parallel}=F_{t1}+F_{t2}, \\ F_{g\perp}=F_{r1}+F_{r2} \end{cases}. $$ On the other hand...
