Thermodynamics: Dead state assumptions
The discussion centers on the assumptions regarding the dead state in thermodynamics, specifically in relation to water's state in a system. It is established that at P = 1 bar and T = 100 °C, water is in a superheated vapor state, as it exceeds the saturation temperature for that pressure. Conversely, at P = 1 bar and T = 20 °C, water is classified as a compressed liquid, indicating it is below the saturation temperature and not in equilibrium with vapor. Understanding these conditions requires referencing steam tables to accurately determine the state of water.
  • Understanding of steam tables and their application
  • Knowledge of thermodynamic states: saturated liquid, saturated vapor, superheated vapor
  • Familiarity with pressure-temperature relationships in thermodynamics
  • Basic concepts of dead state assumptions in thermodynamic cycles
  • Study the use of steam tables for various fluids
  • Learn about the properties of superheated vapor and compressed liquids
  • Research the implications of dead state assumptions in thermodynamic analysis
  • Explore the differences between bar and atmospheric pressure in thermodynamic calculations
Students and professionals in thermodynamics, mechanical engineers, and anyone involved in heat transfer analysis or steam cycle design will benefit from this discussion.
jdawg
Im having a little trouble with knowing what to assume for the dead state! In the question that I posted, I don't understand how they knew to assume that the water in the system is a super heated vapor? Or how they knew that the dead state is a compressed liquid?
You have to match the conditions given in the problem statement with the particular portion of the steam tables you are using.
You can determine the state of the water at P = 1 bar and T = 100 °C by checking the saturation line. Remember, 1 bar is not quite the same pressure as 1 atmosphere (1 atm. = 1.01325 bar), so these conditions suggest that the water is in vapor form. Checking the saturation line for 1 bar will give the corresponding saturation temperature, which will be slightly below 100 °C. Therefore, you can conclude that the vapor is technically superheated, but only by the barest of margins.
As for the conditions of water in the surroundings, P = 1 bar and T = 20 °C, it's safe to assume that these conditions reasonably approximate standard conditions, and water is a liquid. That this is called "compressed liquid" in the steam tables is, I think, a way to distinguish the liquid phase from the saturated condition, where vapor and liquid coexist in equilibrium. The temperature of 20 °C is certainly well below the saturation temperature of water at a pressure of 1 bar.
Thanks! That makes so much sense!
