Thermodynamics, entropy representation problem
fluidistic
The problem is taken from Callen's book (page 36).
Find the three equations of state in the entropy representation for a system with the fundamental equation u =A\frac{s^{5/2}}{v^{1/2}}.
Show by a diagram (drawn to abitrary scale) the dependence of temperature on volume for fixed pressure. Draw two such "isobars" corresponding to two values of the pressure and indicate which isobar corresponds to the higher pressure.
dU=TdS-PdV+\mu dN.
I've been looking in the book for the "entropy representation" and what I understood is that they ask for T(S,V,N), P(S,V,N) and \mu (S,V,N). Google didn't give me a better clue on the "entropy representation" either.
So I've found out the 3 equations of state to be T=\frac{5AS^{3/2}}{2N^2V^{1/2}}, P=\frac{AS^{5/2}}{2N^2V^{3/2}} and \mu =-\frac{AS^{5/2}}{N^3V^{1/2}}.
What destroys me is the next question. They ask me to graph T(V) for a fixed P; as if they had asked me first to find T(V,P) instead of T(S,V,N). Did I get the "entropy representation" wrong?
Apparently what I did is wrong.
The 3 equations of state are \left ( \frac{\partial S }{\partial U } \right ) _{V,N}=\frac{1}{T}, \left ( \frac{\partial S }{\partial N } \right ) _{V,U}=\frac{\mu}{T} and \left ( \frac{\partial S }{\partial V } \right ) _{U,N}=\frac{-P}{T}. I calculated them to be worth \frac{2N^{2/5}V^{1/5}}{5A^{2/5}U^{3/5}}, \frac{2U^{2/5}V^{1/5}}{5A^{2/5}N^{3/5}} and \frac{N^{2/5}U^{2/5}}{5A^{2/5}V^{4/5}} respectively.
I am not sure how to do the diagram though.
To solve this, I first used the units to work out that a= m* a/m, i.e. t=z/λ. This would allow you to determine the time duration within an interval section by section and then add this to the previous ones to obtain the age of the respective layer. However, this would require a constant thickness per year for each interval. However, since this is most likely not the case, my next consideration was that the age must be the integral of a 1/λ(z) function, which I cannot model.
