What is the gas pressure in state 3 if the efficiency is 0.40?
The discussion revolves around calculating the gas pressure in state 3 of a thermodynamic cycle involving an ideal diatomic gas with a specific heat ratio (γ) of 1.40 and an efficiency (φ) of 0.40. The cycle consists of four processes, with constant pressure processes occurring between states 1 to 2 and 3 to 4, while the other two processes are adiabatic. The lowest pressure in the cycle is established at 1 atm in state 1, and the relationship between pressure and temperature during adiabatic processes is defined by the formula P1/γ T^γ = constant, which is applicable under the assumption of reversibility.
  • Understanding of thermodynamic cycles and processes
  • Knowledge of ideal gas laws and properties
  • Familiarity with adiabatic processes and their equations
  • Basic grasp of efficiency calculations in thermodynamics
  • Study the derivation of efficiency in thermodynamic cycles
  • Learn about the relationships between pressure and temperature in adiabatic processes
  • Explore the implications of the ideal gas law in thermodynamic systems
  • Investigate the characteristics of reversible versus irreversible processes
Students and professionals in thermodynamics, mechanical engineers, and anyone involved in the study or application of ideal gas behavior in thermodynamic cycles.
itsjorge
An engine works with an ideal diatomic gas (γ=1.40) according to a thermodynamic cycle consisting in four
processes that take the gas successively through the states 1, 2, 3 and 4. The processes 1 -> 2 and 3 -> 4 take
place at constant pressure and the two other processes are adiabatic. The cycle’s lowest pressure is 1 atm and
corresponds to the state 1.
a. Find an expression for the cycle’s efficiency exclusively in terms of the temperatures of the states 1,
2, 3 and 4.
b. If the efficiency is φ=0.40, what is the gas pressure in state 3?
2. The attempt at a solution
Ok, first part is easy (I guess) here's what I did http://imgur.com/hpBxIex if someone could give it a look I'd be very thankful. I'm sorry I cannot give you the P-V diagram because I don't know how to draw in this PC.
The second part is where it gets tougher because I only have 2 pieces of information and I really cannot relate them. If someone could sketch the solution I'd be very thankful.
OK for part (a). For part (b), think of a way to relate T and P for the adiabatic processes.
Hello TSny, thanks for replying, thing is my professor didn't give us a way to relate P and T however I found this formula in wikipedia but I'm not sure if it's correct: (It's valid iff the process is reversible) P1-γ Tγ=const. What do you think?
The statement doesn't specify if the process is reversible actually...
Yes, that's the correct formula. For these types of questions you can generally assume that the entire cycle is reversible.
  • · Replies 22 ·
  • · Replies 60 ·
10K
  • · Replies 32 ·
  • · Replies 16 ·
