Thermodynamics. Find the Mass Flow Rate of the Air and the Exit Area
The forum discussion focuses on calculating the mass flow rate of air and the exit area for a turbine operating under specific conditions. The inlet pressure is 8 bar and temperature is 960 K, while the exit pressure is 1 bar and temperature is 450 K, with an exit velocity of 90 m/s. The power output of the turbine is 2500 kW, and the user initially calculated a mass flow rate of 0.2777 kg/s, which was incorrect according to their teaching assistant, who indicated the correct value is approximately 4 kg/s. Key equations used include the first law of thermodynamics and the ideal gas law.
  • Understanding of the first law of thermodynamics
  • Familiarity with ideal gas properties
  • Knowledge of enthalpy calculations
  • Basic principles of fluid dynamics
  • Review the ideal gas law and its application in thermodynamic calculations
  • Study the first law of thermodynamics in detail
  • Learn how to calculate enthalpy for ideal gases
  • Explore fluid dynamics principles related to mass flow rate and exit area calculations
Students studying thermodynamics, mechanical engineers working with turbines, and anyone involved in energy systems analysis will benefit from this discussion.
Northbysouth
Air expands through a turbine from 8 bar, 960 K to 1 bar, 450 K. The inlet velocity is small compared to the exit velocity of 90 m/s, The turbine operates at a steady state and develops a power output of 2500 kW. Heat transfer between the turbine and it's surroundings and potential energy effects are negligible. Modeling air as an ideal gas, calculate the mass flow rate of air, in kg/s, and the exit area, in m2
m' = ρvA
ρ = p/RT
du = dQ - dw
h = u + pv
1Q2+m'i(hi+v2i/2 + gzi) = m'e(he + ve2/2 + gze)
p1 = 800,000 Pa
T1 = 960 K
v1 = 0m/s
p2 = 100,000 Pa
T = 450 K
v2 = 90 m/s
Using du = dQ - dw I know that
dw = -2500 kW
I also have:
m'i(hi) = m'e(he + v2e/2)
To calculate enthalpy
h = pv
hi = 2500 kW
he = 2500 kW + (100,000 Pa)(90 m/s)
he = 11500000 W
With this information I should then be able to plug it into the large equation (The 1st law of thermodynamics I believe) and hence get mi
But when I do this I get mi = 0.2777 kg/s which isn't right. My TA said the answer is round about 4 kg/s.
Help is appreciated. Thank you
Enthalpy is Cp*T.
12K
