Thermodynamics of mercury thermometers
The discussion focuses on calculating the pressure of air in a mercury thermometer when immersed in baths at different temperatures, specifically 0 degrees Celsius and 10 degrees Celsius. The initial pressure of the air is 2 mmHg, with an air space length of 10 cm at 0 degrees Celsius and 2 cm at 10 degrees Celsius. Using the formula P = ρ ⋅ g ⋅ h, participants clarify that the density (ρ) of the air changes with temperature, impacting the pressure calculations. The final conclusion indicates that the pressure at 10 degrees Celsius is 82 mmHg, derived from the increase in mercury height due to temperature changes.
  • Understanding of basic thermodynamics principles
  • Familiarity with the ideal gas law
  • Knowledge of pressure measurement units (mmHg, Pa)
  • Ability to apply hydrostatic pressure formulas
  • Study the ideal gas law and its applications in thermodynamics
  • Learn about the effects of temperature on gas density
  • Explore hydrostatic pressure calculations in fluids
  • Investigate the manufacturing processes of thermometers and their impact on accuracy
Students and professionals in physics, engineering, and thermodynamics, particularly those interested in the behavior of gases and the design of thermometric devices.
carlzz7
Please don't ignore the template.
The space above the mercury column in a thermometer ordinarily is evacuated, but due to faulty manufacture, a particular thermometer has a pressure of 2 mmHg of air in this space when the whole thermometer is immersed in a bath at 0 degrees Celsius. Calculate the pressure of the air when the whole thermometer is immersed in a bath at 10 degrees Celsius. At 0 degrees Celsius the length of air space is 10 cm and at 10 degrees Celsius the length of air space is 2 cm.
I started out by using p = rho * g * h. For 0 degrees Celsius I got that rho = 212.31 Pa. I'm not sure that rho would be the same for 100 degrees Celsius though, because the pressure and length are changing. If rho is different, how would I go about solving for it to fill into the formula for 100 degrees celsius?
In the formula P = ρ ⋅ g ⋅ h, ρ is the mass density of the fluid, so it does not have units of pascals. :frown:
Since the manufacturing of the thermometer was faulty and allowed air to enter, it seems the problem is asking you to consider the effect that temperature has on this trapped air, and how this affects the accuracy of the device. :wink:
So the pressure of the air equals the pressure of the mercury. If the change in length is 10cm - 2 cm = 8cm, then the mercury would have increased 80 mmHg. Add this to the original 2 mmHg and you get 82 mmHg at 10 degrees Celsius. Am I thinking about this correctly?
  • · Replies 19 ·
21K
