Thermodynamics question; internal energy and heat?
The discussion focuses on a thermodynamics problem involving a helium balloon cooling from 27°C to 77 K in liquid nitrogen. The participants calculated the new volume of the gas as 0.257 m³ and the work done during the process as 73,400 J. The correct values for the change in internal energy (U) and heat removed (Q) were established as -111,506 J and -185,506 J, respectively. The calculations utilize the ideal gas law and specific heat capacities for helium, confirming the instructor's provided answers.
  • Understanding of the ideal gas law and its applications.
  • Familiarity with specific heat capacities, particularly for monatomic gases.
  • Knowledge of the first law of thermodynamics.
  • Ability to perform calculations involving moles and gas constants.
  • Learn about the ideal gas law and its implications for volume and temperature changes.
  • Study the derivation and application of specific heat capacities for different types of gases.
  • Explore the first law of thermodynamics and its relevance in thermodynamic processes.
  • Investigate the relationship between heat transfer, work done, and changes in internal energy.
Students studying thermodynamics, physics educators, and anyone involved in engineering or physical sciences requiring a solid understanding of gas behavior and energy transfer principles.
name_ask17
A helium balloon with a volume of 1m^3 and temperature of 27 deg c is placed in liquid nitrogen in an open container and cools to a temperature of 77 K. Assume that helium behaves like an ideal gas at constant atmospheric pressure and find the new volume of the gas in the balloon, the change in internal energy of the gas, the work done during the process, and the heat removed from the gas.
i got the new volume=.257m^3
and i got the work with constant pressure=73400J
but i can't get the internal energy and the heat
Q=mcT
U=Q+W
I attempted to find the number of moles and then find the mass to plug it into Q=mct to find Q, but I am not getting the correct answer. Please help
I got a slightly different answer for the work done on the gas. Also, what are you using for the specific heat capacity when calculating Q?
i know the answers should be -185506J for the gas and U=-111506J but i don't know how to get there. i feel like i am doing this problem completley wrong.
Are you using Q = nC_p\Delta T? What would you use for Cp?
Once you have determined the change in volume and the heat flow (out of the gas) you can determine the work done on the gas and then just apply the first law to find the change in internal energy.
You can also calculate the change in internal energy directly. What is the relationship between change in internal energy and change in temperature?
AM
Would i use the specific heat of helium?
Use the specific heat at constant pressure: Cp = R + R(no. of degrees of freedom)/2
Btw, the answers you have given do not appear to be correct. You can see this is the case simply from the relationship between Q, W and U. Changes in Q, U and W are all negative. Therefore, the magnitude of Q must equal the magnitude of the change in U + magnitude of the work done on or by the gas, so |Q| > |U| and |Q|>|W|.
AM
what is R in the equation?
and also when i do that, i have to find the mass to use mcT, so i used the volume divided by 22.4, then multiplied it by the molar mass of helium (4) to get .17857------is that what I am supposed to use for the mass?
also, these were the answers given by the instructor so they should be correct; we have to prove why they are correct.
R = gas constant in J/K mol
AM
im still confused because it did nto give me the right answer.
It is easier to use moles. Mass is irrelevant and using it simply complicates the algebra. First calculate V/T which, from the ideal gas law, we know is equal to the number of moles x R/P:
nR/P = V/T
Since there has been no change in P, or n and R is a constant, the ratio of V/T is constant and so is nR = PV/T
\Delta Q = nC_p\Delta T = nR\frac{7}{2}\Delta T
and
\Delta U = nC_v\Delta T = nR\frac{5}{2}\Delta T
And if they aren't correct you have to show why they are not correct.
AM
alrighty. thanks
name_ask17 said:
alrighty. thanks
I have to apologize. I read helium and thought H2 for some reason. Of course, this is a monatomic gas with Cv = 3/2 and Cp =5/2, so the answers given by your teacher ARE correct if \Delta Q = -185,506 J and \Delta U = -111,506 J. Sorry about any confusion I may have caused.
AM
That's okay. Thank you for clearing it up.
wait. so how am i supposed to find the heat removed? can you show me a formula because i tried everything from Q=mcT and Q=nCT? please help
Since the process occurs at constant pressure, the heat lost is just:
where C_p = \frac{5}{2}R
AM
  • · Replies 25 ·
