Thermodynamics - Temperature change of Argon
19 replies · 3K views
Seven of Nine
The temperature of n = 19 mol of argon gas is increased from T1 = 21 oC by Q = 4.4 kJ heat transfer, while the gas pressure is kept constant. What is the new gas temperature in Celsius degrees?
and as its a monoatomic gas I think this means that the equation is just Q=Cp*change in temp. But I'm not really sure. The Cv of Argon is 0.3122, with R being 0.2081 and Cp being 0.5203.
My last attempts have come up with the final temp as 44.9 - where I had used the mass of the object as 749. I also have got 30.88 by subbing the values into the unknown. I keep getting the answer marked as wrong and I'm not sure where I'm going wrong
HI,
Perhaps you should add dimensions to your quantities and check that the answer has the dimension you want
Do you mean - Cp-0.5203[kJ/kg.K] Cv-0.3122Cp[kJ/kg.K] and then R=0.2081Cp[kJ/kg.K]?
What is ##\Delta T##?
Seven of Nine said:
That's what I want in celsius
Yep. Me too.
But what is it?
Can you elaborate it?
Seven of Nine said:
It's the temperature change in celsius.
cool.
Write that in symbols.
What is the value of the molar heat capacity at constant volume of a mono atomic gas (in terms of R)? What is the molar heat capacity at constant pressure?
CV = (3/2)R and CP = (5/2)R
Or Q = (3/2)nRΔT + nRΔT = (5/2)nRΔT for Cp
and Q = (3/2)nRΔT for Cv
Is that right?
Chestermiller said:
What is the value of the molar heat capacity at constant volume of a monoatomic gas (in terms of R)? What is the molar heat capacity at constant pressure?
I have 32.14 when I do - (4400/((5/2)*(759)*0.2081))+21 that's when everything is in grams? Is that correct
So, ##\Delta T## is change in temperature, right?
Now, say, initially the temperature is ##T_i## and finally ##T_f##.
What is the change in temperature?
Yes so the final Temperature was 32.14 - I submitted it and it was correct - with the change in temp being 11.14. This was found but using the molar mass - The molar mass of Argon is 39.95 which is multiplied by the 19mol so 759.05. Then sub into the equation above and then add the initial value to get 32.14
How did you obtain the value ##32.14##?
So your initial equation was wrong!
It should be $$Q=m\cdot {C_p} \cdot {(T_f \sim T_i)}$$
The initial equation is correct I have just subbed in the equation for Cv and the value for n in the initial equation is 1 or excluded as Argon is monoatomic and I got 32.14 by adding the initial value of 21 to the change in Temp which was found using the equation. To give the final Temperature
The question clearly says "the temperature of ##n=19~\rm {mol}## of argon gas ..." why did you use ##n=1##?
How did you find the change in temperature to add with?
You didn't even need to know the molar mass of argon if you just used the universal gas constant R = 8.314 J/mole.K:
$$(19)(2.5)(8.314)\Delta T = 4400$$
So, $$\Delta T=11.14\ C$$
Isn't your unit for ##T## - ##K##?
For a temperature change, K and C give the same number.
