Third Law of Motion :Confusion
When pushing a crate, the force exerted by the person results in an equal and opposite force from the crate, but friction between the person's feet and the ground prevents them from sliding backward. The frictional force on the person's feet must be strong enough to counteract the force from the crate; otherwise, they may slide backward if the crate has greater friction or weight. If both the person and the crate are on a frictionless surface, they would both move in opposite directions due to the push. The net force acting on an object determines its acceleration, highlighting the importance of friction in this interaction. Understanding these dynamics clarifies why the crate typically moves forward while the person remains stationary.
moatasim23
When we push a body say for example,a crate on ground.Then in response to our force the crate also exerts a force on our hands.Then my question is why does the crate move forward and not we that move backward?
Science news on Phys.org
Because your feet are in contact with the floor and there is a force of friction on your feet from the floor exactly equal and opposite to the force on you from the crate, because friction acts in exactly the way it needs to to prevent your feet from moving.
There is a limit to how strong friction can be though, and it won't necessarily be the crate that moves. The crate is in contact with the floor too and if it can sustain a higher friction force than your feet (because it is heavy enough or the materials have more grip) then you will move backwards before the crate moves forwards. Try pushing as hard as you can against something heavy with good grip, a car with the brakes on for instance, with your feet up close to the car and say wearing socks to keep friction low, I think you'll find that it's you that slides backwards.
The interaction between you and the crate involves equal and opposite forces that you exert on each other.
Whether an object accelerates depends on the net force acting on it. Presumably there are other forces acting on you, such as friction from the ground to hold you steady. But if you and the crate were on frictionless ice, then you would both move as a result of your push: You'd move backward and the crate would move forward.
I was watching a Khan Academy video on entropy called: Reconciling thermodynamic and state definitions of entropy. So in the video it says: Let's say I have a container. And in that container, I have gas particles and they're bouncing around like gas particles tend to do, creating some pressure on the container of a certain volume. And let's say I have n particles. Now, each of these particles could be in x different states. Now, if each of them can be in x different states, how many total...
Thread 'Why work is PdV and not (P+dP)dV in an isothermal process?'
Let's say we have a cylinder of volume V1 with a frictionless movable piston and some gas trapped inside with pressure P1 and temperature T1. On top of the piston lay some small pebbles that add weight and essentially create the pressure P1. Also the system is inside a reservoir of water that keeps its temperature constant at T1. The system is in equilibrium at V1, P1, T1. Now let's say i put another very small pebble on top of the piston (0,00001kg) and after some seconds the system...
